Results 1 to 11 of 11
Thread: Pentair minimax NT blower popped then stopped working
    Mar 2016
    Santa Maria
    11
    The blower ran for 15-30s, a loud pop occurred, and it will not start again. This was prior to the ignition cycle. It happened the day after it rained. I have the heater cover off now to inspect, and water certainly could NOT have gotten into the blower motor itself. What happened?
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Pentair minimax NT blower popped then stopped working
    Who knows for sure what happened. Maybe the capacitor on it blew. Does the unit come to life other than the blower working? If all else seems fine and it's just that the blower stopped working, then is sounds like you need a new motor.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Mar 2016
    Santa Maria
    11
    Yes, the water pressure switch and thermostat work. The blower does not start, so the ignition cycle does not start.
    Learned yesterday after I left the heater on for a while, error code 4 came on which is the fan.
    Now...replace the blower or replace the heater? Choices. The heater is 10 years old already and discontinued. We'll see.
    Thank you
    Mar 2016
    Santa Maria
    11
    I have a 1,500 gallon spa with second pump for a waterfall that flows into the spa. The main pump is a 3hp Pentair. Piping is 2". If I buy a Pentair 125k Mastertemp with 1.5" piping, will it reduce the performance of or damage my setup?
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Usually the cost difference between the smaller and the 250K units isn't much.
    Paul
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    I usually would rather have a customer repair than replace. Except when...
    The heater is over 10 years old.
    The heater is a MiniMax NT.
    You have two strikes.
    Factory Warranty Station for:
    Mar 2016
    Santa Maria
    11
    Fair enough. I want to give a chance to the blower...is the capacitor attached to the blower motor casing the start capacitor? Is it a 5 microfarad capacitor? 370/440 VAC?VZM.IMG_20160315_193645.jpg
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Yes that is the start run capacitor and yes 5 micro. I would also inspect the squirrel cage on the motor as well. If it's in bad shape it would be better to replace with a new motor.
    Paul
    Mar 2016
    Santa Maria
    11
    Thanks. While I found a replacement capacitor, I ordered a new motor (duh, the capacitor specs are on the motor housing). Hopefully I can get another year or two out of the heater.
    1,500 gallon spa with waterfall
    Two Pentair Pumps
    Pentair Minimax NT 300,000 BTU Heater
    Sep 2014
    Oregon City, OR
    3
    Where did you find a replacement motor?? I've been searching for a week and can't find a direct replacement. Your help is greatly appreciated!
    Brian
    Mar 2016
    Santa Maria
    11
    Quote Originally Posted by binduni View Post
    Brian
    TC Pool Equipment
    Two Pentair Pumps
