Results 1 to 16 of 16
Thread: New pump motor
    Sep 2013
    Charlotte, NC
    41
    New pump motor
    Hi all
    My pump comes on and makes a humming noise and then cuts off, then restarts after 15 minutes. So I think, after several reads, that a motor replacement is the way to go.
    Currently there is a pentair 1.5 HP WF-26, I wish I could post the picture, but I couldn't.
    My question is, should I replace just the motor or get a new pump. No spa no water features.
    If a new motor only, what I'm leaning toward, just a 2 speed is enough. VS is a little pricey and I can't see the savings.
    Thanks in advance.
    26K gallons, IG vinyl, Pentair 1.5 HP, Hayward DE filter, TF 100 test kit, Ecojet Turbo Cleaner
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: New pump motor
    That usually just means that it needs a new capacitor which are easy to replace. I would check that first before replacing the entire motor. Does the motor shaft rotate freely?
    But if you want a two speed for the WF-26 wet end, then you want a A.O.Smith B2982 or equivalent. It is a 230v motor so just make sure you can wire it that way.
    Mark
    Sep 2013
    Charlotte, NC
    41
    Re: New pump motor
    Thanks for your reply. I dont know, will remove tomorrow and Check.
    Sep 2013
    Charlotte, NC
    41
    Re: New pump motor
    I checked the impeller and it looks good. I'm going to replace the capacitor and see what happens. Thanks.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: New pump motor
    If you have a multi-meter you can check for an open or short on the capacitor. It could also be a centrifugal switch if the motor has one.
    Mark
    Sep 2013
    Charlotte, NC
    41
    Re: New pump motor
    OK capacitor was bad. I replaced it. But still no luck.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: New pump motor
    Did you ever check the centrifugal switch in the back? Contacts can get dirty.
    Also, you said you checked the impeller but did you turn it with your hands to make sure there is no binding?
    Mark
    Sep 2013
    Charlotte, NC
    41
    Re: New pump motor
    I did turn the impeller. Removed the screw in the middle and turned. I'm going to check again.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: New pump motor
    No, don't remove the screw that defeats the purpose. You want to turn the shaft as well so the impeller has to be screwed to the shaft.
    Mark
    Sep 2013
    Charlotte, NC
    41
    Re: New pump motor
    Got it. Is back on it and it does move. I have Not been able open the back of the motor, screws are Not coming out, have to figure out a way to do it to Check on centrifugal switch.
    I believe per the diagram I have to remove the long screws for the back correct?
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: New pump motor
    Those are the housing screws. There should be two shorter screws that hold on just the end cap.
    Mark
    Sep 2013
    Charlotte, NC
    41
    Re: New pump motor
    Nothing there.
    Any further help I can get is appreciated.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: New pump motor
    It isn't clear from that picture if the motor has a centrifugal switch or not. It should be attached to the shaft so you might be able to see it from the outside. If not, for that motor design, you would have to remove the housing screws to see.
    Mark
    Mar 2015
    New Orleans, LA
    81
    Re: New pump motor
    Stop fighting it and replace the motor. They are not that expensive.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: New pump motor
    Quote Originally Posted by mas985 View Post
    If you decide on going with a new motor.
    Mark
    Sep 2013
    Charlotte, NC
    41
    Re: New pump motor
    Thanks, I checked again and is not there. Will go with your suggestion for the new motor. Thanks.
    I'll be back. I'm pretty sure.
