Thread: Solar paused pump alarm
    Mar 2016
    Cape Coral
    3
    I keep getting the error message "solar paused, pump alarm" on my solartouch controller. It happens randomly and only when the pump is not scheduled to run. It happens daily and I am not having power outages. Pentair thought it was the controller and sent a new one. It is still happening. We are baffled. Why is the pump causing this alarm?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Solar paused pump alarm
    Can you tell us what the rest of your equipment is, and did you swap out temperature sensors also (they are probably the most failure prone part to solar controllers)?
    Mar 2016
    Cape Coral
    3
    Sure, I have a 9000 gallon in ground pool with approximately 600 square feet of solar panels on the roof. The solar touch controller controls an intelliflo pump and three way valve that sends water to the panels when solar heating is available. The entire system is less then 3 months old and we have had the "solar paused, pump alarm" problem from day one. I think we have now ruled out the controller as the problem. I checked the system this evening after it shutdown and everything is good to go. The controller has the solid green light lit. When I check tomarrow morning odds are it will be in the alarmed state once again.
    Mar 2016
    Cape Coral
    3
    I should have also mentioned it is a salt water pool. Chlorine levels are maintained by an autopilot chlorine generator.
    FloridaSolarPro's Avatar
    Oct 2011
    Fort Myers, FL
    49
    All this means is the roof sensor is warmer than the water sensor and the controller thinks it can heat the pool, but it senses the pump is not running. Most of the time this is a non-issue. When the pump starts the error will clear and the solar will come on.
    Jason Szumlanski
    Vice President
    Fafco Solar
