Results 1 to 14 of 14
Thread: Bury or Not to Bury an Above Ground Pool?
    Mar 2016
    mesquite tx
    3
    ...this is my first post,but this is the subject that interest me & wife the most. We are considering purchasing a AGP, but want to bury it or at least semi bury it. We have a slope in our yard & would like the front of the pool to be flush or closest to the ground. We don't mind the back being exposed or partially exposed,because it will be closest to the fence & plan to put the pump,equipment,etc....on that side. I've read that Doughboy makes the only AGP that can be buried, is this correct? We recently went to the Dallas Home & Garden show & worked out a deal with a company that sells Discovery & Nova brand pools, but don't want to purchase this brand, if we can't at least semi bury it....any input would be helpful, thanx in advance......
    Oct 2012
    209
    Re: Bury or Not to Bury an Above Ground Pool?
    It can be done, but it must be done right, I personally wouldn't recommend burying more than halfway.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Mar 2016
    mesquite tx
    3
    ...thanx for the reply...I talked with a distributor of Doughboy today & plan to talk/meet with someone from Discovery & Nova pools tomorrow
    2kCougar's Avatar
    May 2015
    Albany, NY
    35
    Ours is partially buried. This picture was taken before all of the backfill was done. The back edge is less than 6" from the top of the pool
    I have pics in this thread:
    Deck size?
    24' Radiant metric semi-inground, Hayward S180T92S, 8/2015 install, TF-100
    Mar 2016
    Raleigh, NC
    4
    I am in a similar situation. Have you looked into a Fabcote Ultimate Pool? Says it can be installed above, semi or inground. Im trying to find more info and reviews.
    May 2015
    Gulfport, MS
    109
    my pool is semi inground, no problems in the first year of ownership.
    12X20x54" Saltwater 8000 semi-inground, Waterway 1.5hp 2speed 22" Pump Sand Filter, Hayward Goldline Aquatrol HP SWG, TF100
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    512
    My pool is buried about 24 inches.. I have about a foot slope in my yard. It was done in 2014.. no problems with it.
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
    jbriggs1219's Avatar
    Apr 2015
    Brunswick/Ohio
    77
    Mine is almost completely buried at top as I have huge slope in my yard..two years in and no problems....my neighbor with same slope has his buried that way for almost ten years and no problems
    13,500 gallon AG
    Cartridge Filter
    Raypak Natural Gas Heater
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Mine is half buried into a sloped yard, but it is also rated for a buried install. You can check the link in my signature. I left it out of the ground just enough to put in my deck on that side.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    My pools in-ground side is approx 24" into the ground and slopes to being out of the ground on the low side. This will be the 10th season and no problems as of yet. My bottom track is plastic(PVC?) not metal.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Mar 2016
    Attleboro ma
    1
    Hey. I am brand new here and to forums in general. I am with Matt. I just put in a 24' Radiant last year. It is buried all the way up around 1/3 of the pool. They are built for that.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I put in a Doughboy at my parents house about 30 years ago that is buried about 2 ft on one side with no issues still. I think they put nickel or zinc in their metal if I remember right that helps with corrosion. What ever they do those pools last a long time!
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Mar 2016
    Tampa
    17
    make sure there is good drainage. once you dig the hole, get it installed and back filled, the hole will be susceptible to flooding. I mean in heavy rain, the soft back fill dirt will absorb water much quicker than the surrounding dirt, creating pool around your pool which will make your liner neutrally buoyant, causing it to lift and wrinkle in places. it would best to have some type of hardscape around the pool to help drain the water away. This is just my experience with it. other than that, I haven't had any major issue with my install.
    15 foot round pool that I partially buried 24 inches. Vinyl liner. About 5000 gallons. Two HP two speed pump. Set on a timer to run for eight hrs a night. Water way filter housing. Laars ld250 propane heater.
    Jul 2016
    Baltimore, Maryland
    1
    Hey there. We recently put up a 22' round pool from intex. It has vinyl sides. In order to get the pool intp the spot, we had to dig and now there is a gap between the pool and the ground. We would like to fill it in. Where can I get some ides for doing that?
