Results 1 to 18 of 18
Thread: skimmer sock
    Aug 2008
    Las Vegas, NV
    116
    skimmer sock
    I had lots of people say we needed this. So I went the cheap way and used a knee high. OMG the stuff that is coming through the filter. Since I started using it, the surface area of my pool is MUCH cleaner. When I take it off to rinse, I am amazed at the layer of gunk. What is that stuff? Could it be "baby algae" or just some sort of organic material? Typically my pool looks very clear and my FC has been holding steady. I was just wondering if this is a precursor to an algae outbreak.
    Thanks
    Pam
    Re: skimmer sock
    This time of year there is an amazing amount of pollen in the air, which is what your skimmer sock is catching.
    Aug 2008
    Las Vegas, NV
    116
    Re: skimmer sock
    Since I am leaving town for several days and will not be here to clean the skimmer sock, I guess I should take it off until I get back. Even after just 24 hours, it was so coated! I think if it's still this bad next week, I'll clean it twice daily. No wonder my sinuses are so clogged!
    Pam
    Butterfly's Avatar
    South Carolina
    10,045
    Re: skimmer sock
    Pam, you are right, take that sock off while you are gone
    I clean mine 2X day now, but I have needed to clean them as often as every hour
    It is amazing what a skimmer sock keeps out of your filter. Not only that, you get to SEE it and be amazed by it all! Oh yeah, our poor sinuses!
    I buy my skimmer screens (socks) from WallyWorld. They are a finer mesh and really catch everything!
    You're done SLAMing when:
    Jun 2007
    NC
    255
    Re: skimmer sock
    Quote Originally Posted by my2kidsmom
    ...I guess I should take it off until I get back..
    Definitely take it off while you are gone!
    I keep a 'stockpile' of them and change the twice a day since I have a pool that's surrounded by 60-80' oak and maple trees. It makes cleaning the skimmer easier right now 8) .
    Terry in NC
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    Apr 2009
    Virginia Beach
    4
    Re: skimmer sock
    I bought skimmer socks from Wally World. They worked great, too good in fact. When I checked 2 hours later they were so full of pollen they had been sucked down to the bottom of the skimmer, and almost no water getting through. I had to wash them off every hour for a day before I could leave them unattended for a while.
    Is that bad for your pump?
    Jun 2007
    NC
    255
    Re: skimmer sock
    Quote Originally Posted by mvtton
    I had to wash them off every hour for a day before I could leave them unattended for a while. Is that bad for your pump?
    Pumps are not designed to run very long without a supply of water, usually just until the priming takes hold which is a few minutes from my understanding 8) .
    Can you set your intake on the pump so it pulls some from the skimmer and some from the main drain? That way the pump will never run out of supply water: If the skimmer fills up with "gunk" (a technical term!) the pump pulls more from the main drain but the pump is never starved for water.
    Triad Region of NC
    Re: skimmer sock
    The skimmer socks are definitely the real deal. After the nasty pollen wars of early April, I can now leave them unattended for a few days without rising it off. I used to buy them from Walmart but now I get them online.
    Pool Size: 8600 gallons - rectangle 12'x24'
    Pool Type: Inground with vinyl liner
    Filter: Hayward Pro-Series S244T - 300# Sand Filter
    Pump: Astral Pools IGP2010 - 1HP
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Re: skimmer sock
    I have had similar experience with skimmer socks. For those of you with a sand filter, you can try the D.E. trick. It worked so well that right now I am not using a sock at all, and my water is clearer than it was with the nasty disgusting sock that required constant cleaning. I still have my 4 cheapo socks (one died a horrible death) and will still use them under some circumstances, such as our neighbor mowing his pasture for 4 days straight or when we mow our pasture or during the worst of the pollen wars. But so far, the little bit of DE in the sand filter has taken the place of the sock for me.
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    Re: skimmer sock
    Love my skimmer socks.. so knee highs really work? I may switch as the skimmer socks are $15 for 5.
    2003 Marquis Euphoria - 400gal
    Aug 2008
    Las Vegas, NV
    116
    Re: skimmer sock
    What is the D.E. trick?
    Pam
    Re: skimmer sock
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    572
    Re: skimmer sock
    I bought some food grade DE a few years ago to kill bugs. I still have quite a bit of it left and was wondering if I can use it in my sand filter, or do I need to get pool grade DE instead?
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Re: skimmer sock
    Food grade DE won't work nearly as well. Pool DE is heat treated, which gives it lots of sharp points that help trap dirt and debris.
    Apr 2009
    S.E. MI
    572
    Re: skimmer sock
    Ok, thanks, Jason. Bummer though since I have so much of the food grade kind left. It works great on killing insects but the downside is every time it rains out, you have to treat again.
    Re: skimmer sock
    I read the manual that came with my Pentair 520 cartridge filter and they said to add DE to the skimmer as well. I didn't but maybe I should. I wonder what "first time operation" means, I've been operating for 2 days now.
    http://www.pentairpool.com/pdfs/CleanandClearPlusOM.pdf
    NOTE
    For first time operation on new pools introduce into the system .75 pounds of diatomaceous earth per every
    100 square feet of filter area (a one-pound coffee can equals .5 pounds of diatomaceous earth). Mix the diatomite
    with water and pour it into the skimmer after the pump is primed and the system is operating. This will enhance
    the filtration of your water.
    7,500 In-Ground gunite / marble plaster. VS-3050 & VS+SVRS Variable Speed Pump. Rainbow-inline chlorinator (not even used for vacations). Pentair 520 cartridge filter. Paramount Clear O3 generator. SunTouch Controls. Pentair Legend Platinum.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: skimmer sock
    As you can see from the Unicel cartridge cleaner instructions in this post, not all cartridge manufacturers think that using DE is OK. Their specific quote is as follows:
    NOTE: Unicel does not recommend the use of diatomaceous earth (DE) with cartridge filters. DE particles will become trapped in the body of the media and shorten cartridge life. If desired, a cellulose fiber (synthetic DE) can be used in moderation.
    Re: skimmer sock
    Excellent, I will leave the DE out of my filter as well regardless of what the manual says. I was hesitant to add 4 pounds of DE to my cartridge filter anyway.
    I think I will try the sock though.
