Thread: How much salt
    Jan 2010
    Randleman,NC
    620
    How much salt
    Hayworth Auqa Trol being installed.24 ft round 52 in deep.How many pounds to be expected to dump in water on start up.Pool guy told me to get 14 bags at 50 pounds a bag.I bought 15 bags.Sounds a little high to me.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    JoyfulNoise's Avatar
    May 2015
    13,236
    Re: How much salt
    Quote Originally Posted by kplaster View Post
    At 24' round by 48" deep (I'm assuming the pool height is 54" but the actual water depth will only be 48"), to go from 0 to 3600ppm (avg optimal salt value of most SWGs), you would need 407lbs of pool salt. If you assume the full 4-1/2 ft depth, then the amount of salt needed is 458lbs. You've got about 750lbs there which is a lot more than you need.
    Are you sure those are 50lbs bags? Most pool salt is sold in 40lbs bags.
    Is your fill water well water or municipal water? Muni water often has a small chloride level to begin with (can be anywhere from 50-200ppm depending on the provider).
    Matt
    Jan 2010
    Randleman,NC
    620
    Re: How much salt
    24 round 52 on wall.He told me to go to Southern States.I bought 50 pound bags of Champion Mix &Fine Salt.99.5 % pure salt.
