Results 1 to 11 of 11
Thread: How long to circulate before retesting?
    PDXJenn's Avatar
    Jan 2016
    Portland,OR
    13
    So my cc got away from me again and I'm slamming the pool. My question is, after I put in the chlorine, how long before I check again to see if I've eliminated it yet? It's an Endless Pool so I turn on the current and mix it like crazy for a few minutes. Should I check it again then right away, wait 15, wait 2 hours, or what?
    I want to avoid NOT adding enough chlorine and making it worse.
    Thanks folks!
    Jenn
    indoor 8x14 original Endless pool (3800 gallons)
    dark blue vinyl liner, inline UV bulb, recessed automatic retractable cover
    covered unless in use
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: How long to circulate before retesting?
    With it being so small I bet 15 mins would be fine to retest. Let us know how it is going.
    Kim
    PDXJenn's Avatar
    Jan 2016
    Portland,OR
    13
    Thanks Kim! I've been checking it several times today because I was trying to wait "long enough" without knowing if breakpoint is reached and then bam, cc is gone, or if it's a longer thing. Raised chlorine from 4 to 11 and now finally am not getting cc when I test, phew.
    So now I just wait for it to come down to a swimmable level, right?
    Aug 2014
    Northern IL
    4,615
    Keep FC at shock level until the slam is done. Just getting rid of CC's isn't enough. There is a link within the following link about how to perform an OCLT. Pool School - SLAM - Shock Level And MaintainIs your water crystal clear?
    PDXJenn's Avatar
    Jan 2016
    Portland,OR
    13
    "Overnight" is 8-12 hours, right? It's indoors so I can disregard the light thing.
    So I'll check in like an hour and make sure there's no more cc and then watch it for the next 8, and if it drops more than 1 ppm I'll maintain instead of watch. Ok.
    thank you!
    Aug 2014
    Northern IL
    4,615
    You go! I think 8-10 hours should be good. Is the water clear?
    PDXJenn's Avatar
    Jan 2016
    Portland,OR
    13
    Water has been beautifully clear the whole time, no smell, all other parameters correct. Holding chlorine now at 12 (up from 4) and getting a slight pink again on the cc, doh. Going to watch it for another hour and recheck. I would like it to be swimmable tomorrow midday when we have people coming over, even if I need to use Chem-Out, but I need the durn cc to be banished and stay gone first. Maybe not gonna work anymore.
    I've got the window open and ceiling fans on high, too, hoping to speed it up a bit.
    Aug 2014
    Northern IL
    4,615
    Let us know. The ventilation should help too! Have you ever used MPS?
    PDXJenn's Avatar
    Jan 2016
    Portland,OR
    13
    Hesitant to use MPS because I've heard it can cause skin reactions and two out of 5 family members are very sensitive. Been keeping them out of the pool any time chlorine is above 5, and of course if cc is present...
    Aldo trying to follow instructions from Endless Pool combined with all I've learned here on the forum. EP says nothing about non-chlorine shock, and recommends liquid chlorine so that's what I'm trying to do. I have the UV light and a Nature2 cartridge (can't decide if I should chuck that.)
    Because it's an indoor pool I can't ever burn anything off, so it's hard to figure out how to not let the cc get away from me, and ideally we want to swim and this is the third time where I've had to put the family on hold until I get the pool back in order, . We've had it since December. Keeping it at 86 may make it more like a spa, too, so I read all I can in spas and indoor pools to help me get a clue about things.
    PDXJenn's Avatar
    Jan 2016
    Portland,OR
    13
    A new day, same old pool, still getting cc this morning after maintaining chlorine at 12ppm overnight. Grrgh.
    The weird thing is that the TC level doesn't drop, it just stays there. So it's not being used up but I'm still getting new cc, so then I add more bleach for that, etc etc.
    Tell me more about MPS if I wanted to use it. Could I do it selectively and still eliminate prior to using it?
    JoyfulNoise's Avatar
    May 2015
    13,213
    I would only use MPS as a last resort. Consistent use of MPS will build up sulfates in your pool and that can cause problems when they get high enough. Also, MPS will interfere with the DPD-FAS test requiring you to buy an extra reagent to account for the MPS.
    It sounds like you might need to invest in some form of supplemental oxidation. You said you have a UV source but it may not be powerful enough. Paramount makes a UV system capable of holding up to 4 UV-C lamps. You might need that. Ozone is another form of supplemental oxidation you can use. You might have to keep the pool uncovered and use higher doses of chlorine in between swims to keep the CCs down thus treating the pool more like a hot tub.
    Matt
