Results 1 to 18 of 18
Thread: New pool and hardscape construction in Ellicott City Maryland
    Oct 2015
    Ellicott City/MD
    8
    Hi everyone,
    After a few obstacles thrown at us by the county we're very excited (and a little anxious and stressed!) with getting this project started. Trees have come down and demo of the old patio is in progress. I'm going to try my best to post pics and some time-lapse video of the project.
    I would love any feedback or suggestions. We are first-time pool owners and want to make sure we are making good decisions and choosing the right options before everything is set in stone.
    Here's some info:
    Pool:
    • 770SF freeform gunite, 3'.6"-8' depth with raised beam
    • Nicolock Fullnose 4x12" coping in Travertina color
    • Baja shelf
    • 2 Pentair Lighted Sheer descents with booster and controller
    • 2 Pentair LED lights
    • 3 Colorcascade LED blubbers
    • Pentair IC-40 salt purification
    • Pentair 3HP Intelliflo VS pump
    • Pentiar Easy Touch 8 Control Panel
    • Pentair Screen Logic Bundle for Mobile Integration
    • Pentair FNS Plus 60 DE filter
    • 2 Skimmers, 4 returns
    • Goby pressure cleaner with booster pump
    • Raypak 406A Digital 399K btu propane heater
    • DiamondBbrite (Still need to decide on color, but so far it's Super Blue)
    • 6" waterline tile, steps and benches tile
    Paver Patio and Pool Deck:
    • Nicolock Stoneridge and and Stone Ridge XL pavers (random pattern) in Travertina color
    • Pool border and soldier course will be in Nicolock Ridge Brick in Golden Brown Blend or Oyster.
    Natural Stone Retaining Wall, Steps, Grill Station and Fireplace:
    • Marriottsville natural stone (local quarry) in a stacked design
    • Steps and grill counter, fireplace hearth, teirs, mantle and raised hearth: 2" thick PA Bluestone treadstock (edges thermally finished)
    • Grill and Wok burner by Alfresco (LP gas)
    Last edited by tlmxyz1; 03-12-2016 at 08:56 AM. Reason: Updated the design image to show more info
    Construction started, due June 2016: 770sf freeform 42' long swg gunite 3 6"-8' w/ 2 skimmers 4 returns, sun shelf w/ umbrella holes, volleyball net poles. Pentair Equipment: 2 lighted sheer descents, 2 color LED pool lights, 3 color LED bubblers, 3HP Intelliflow pump, IC 40 SPS, EasyTouch 8 w/ Screen Logic, FNS Plus 60 DE filter. Raypak 406A, 1 HP Booster pump. Nicolock Travertina pavers (Considering Diamond Brite Super Blue finish).
    Jun 2014
    15,110
    Re: New pool and hardscape construction in Ellicott City Maryland
    Hello and welcome to TFP! That should be quite a show when it's done. Make sure to post pics for us. Your proposed set-up look pretty solid to me, although I might ask to confirm with the builder if 4 return jets is adequate enough for your size pool. Two skimmers is great, but then you want sufficient water getting pushed-back towards those skimmers, taking into account "dead spots" in circulation due to curves and angles of the pool itself. That's the only thing that caught my eye. You'll see more replies as well I'm sure. Nice to have you with us.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    This all sounds quite exciting! I'm sure the last few days of 80 degree weather has gotten you in the spirit! I'll just make a few comments:
    - Consider dropping the pressure cleaner and booster pump. A good robot is really a better choice - no extra pump to run, all self-contained.
    - Upgrade one more size to the IC-60 SWCG. It will last longer and make the long-term cost cheaper.
    - If you haven't, give ample consideration to your volleyball net setup/inserts. You will want to pick out your exact system now before construction begins - since it would need to be bonded and considered prior to decking. Honestly with your setup going on here, I'd get a high end stainless system with the largest poles/bases you can. Such as this...https://www.coolpoolproducts.com/pro...ll-System.html There may even be better systems. Your depth profile isn't the best for volleyball but the deep end folks can be on floats. We did not go with volleyball but just a heavy duty portable basketball hoop. (Which you can see in our build thread in my signature -and good job on your signature BTW).
    I'll let others comment if they feel the DE filter is sized appropriately (i.e. appropriately oversized)
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Wow, nice plan!! And big pool!!! We're about to get DB super blue next week, drop me a note if you want to see it in person -- I'm in Annapolis.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Oct 2015
    Ellicott City/MD
    8
    Thanks Pat,
    I appreciate the advise on the returns. I'll going to meet with the meet with the designer today, how many more jets would you recommend?
    Tim
    Oct 2015
    Ellicott City/MD
    8
    I forgot to also say "Beautiful pool!". I love the color of the stone around the edge and the water fall.
    Oct 2015
    Ellicott City/MD
    8
    Thanks neighbor,
    Yes, the 80 degree weather definitely helps but as you know we could get snow in April! Thanks for all the great advice, I'm going to bring up all of these details with the designer today. I just quickly went though your build pics and I have to see it's amazingly beautiful. I'm going to take a closer look at your build process over the weekend. They are scheduled to dig the pool week after next.
    Tim
    Oct 2015
    Ellicott City/MD
    8
    Hi Helen,
    Thank you, we love the plan too. It was our second plan due to a few county septic obstacles. We would love to see the Super Blue in person, I'll drop you a note.
    Tim
    Apr 2013
    Sacramento, CA
    2,769
    A couple comments.
    You are the cusp between 1 and 2 skimmers -- talk to the PB -- If you get two you want them to collect debris from different wind patterns.
    Four returns is probably enough, Five or six would be better
    Lights are a problem. They can be difficult to service below a swim out and you want them facing away from the seating areas -- You need the two LEDs They should not go on your back wall.
    Get the largest SWG and filter you can afford. Its not that expensive to oversize both. If you have an algae problems you will thank me for the oversized DE Filter.
    Go with a robot. Much less expensive.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,492
    The above have you covered with ideas. I just wanted to say HI! and thanks for letting us spend your money! LOL
    Please share a picture of where your pool is going. Use photobucket to add the pictures.
    Kim
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Try to resist Kim's urges to use glitter grout, surely no good will come of that...
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Quote Originally Posted by tlmxyz1 View Post
    Hi everyone,
    Here's some info:
    Pool:
    • Baja shelf
    Attachment 45628
    Great planning! We used to live in Ellicott City in the 80's. Wonderful area. Looking forward to progress reports. Buy a good brush.
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    Jul 2012
    Tallahassee, FL
    30,492
    shhhhhhhhhhh LOL Helen I was saving that as a surprise for them!
    Kim
    Oct 2015
    Ellicott City/MD
    8
    Thanks for your advice and input. With lights, are you referring to the sheer descent lights at the top of the pool? The LED 2 pool lights must have been left off of this revision, there going to be the right side of the pool. We do get a lot of algae on the house and in the pond so I'n definitely going to look into the larger SWG. I also need to get a better understanding of how to determine the number of returns for a pool.
    Tim
    Hi Kim,
    Your welcome! Thanks for the shout out. Click below to see the before shot:
    screenshot.net/l6o42i2
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    Hopefully you are still able to get some good sun with the tall trees around, or your heater and wallet will get a workout. Do you plan to use a solar cover? Any cover will be very helpful to retain heat at night and on breezy days.
    Jul 2012
    Tallahassee, FL
    30,492
    That is a pretty yard! WOW! This will be fun to plan and do!
    Kim
    Oct 2015
    Ellicott City/MD
    8
    Quote Originally Posted by Helen203 View Post
    Omg, what a great idea, where do I find such a thing? Haha
    Oct 2015
    Ellicott City/MD
    8
    Quote Originally Posted by bmoreswim View Post
    We had a bunch of trees taken down, not sure if it's enough. I'd like to look into a solar cover too.
