Results 1 to 11 of 11
Thread: pool water temps getting into the 60's
    Dec 2015
    Newington, Connecticut
    113
    Water temps are getting above 60 degrees around here a month earlier than last year. Pool was installed in April last year and haven't experienced the spring start up. Closing chemicals were added when closed but didn't know if I should be adding chlorine. Not sure how long temps will be up but will be for the next week. Any thoughts?
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    Mar 2016
    Central CT
    78
    Re: pool water temps getting into the 60's
    I'm in your neighborhood and was starting to wonder the same thing. I can't believe the water is so warm in march.
    20K gallon 32 ft x 16 ft vinyl liner in ground pool || sta-rite modular media P150 cartridge filter || .75 HP whisperflo dual speed pump
    Taylor K-2006 Test Kit
    Aug 2014
    Northern IL
    4,615
    If it were me, I would go ahead and open. I would rather open clear than fight algae. Time is money, and fighting algae is time!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Here at TFP we say "open early, close late". With the non-winter this year early is going to be REAL early. Open that baby up!
    Kim
    Dec 2015
    113
    Sounds like 60 is the magic number. Of course that was the top of the water that I was measuring ill have
    To get the pool thermometer out and fish it in the cover. I have a sump pump set up that will allow me to circulate some bleach into the pool until I get everything in order for opening. Wow this is early!
    Mar 2016
    Central CT
    78
    I looked under the cover on Wed and hung my pool thermometer as low as it would go and got around 55 I better order a pump this weekend.
    Dec 2015
    113
    Did the same with the thermometer and got lower temps. 45degrees. So I think I got a little time. Over night temps are lowering back down. What town are you in bigevilgrape?
    Mar 2016
    Central CT
    78
    I'm in Newington too.
    Ellington, CT
    262
    I'm up in Ellington. Usually in early April I set up my pump, put it on recirculate and pull back a corner of the pool cover and put in some chlorine. I check the chlorine level once a week until I fully open the pool in early to mid May. This in combination with closing the pool at the end of Septermber per the guidance from TFP results in never having to deal with a green pool at opening. I also send in my robot with spring clean up filters once a week during this time.
    Looks like I need to get out to my pool today and check the temperature and maybe start my routine a little earlier this year.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    452
    Quote Originally Posted by Andrew Howard View Post
    Water is cooler the deeper you go.
    Personally, I typically open in mid-May so the water is ready by Memorial Day, but that was with Baquacil. This is my first season opening with Chlorine.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    JayG's Avatar
    Aug 2015
    Harrison, NY
    199
    I'm in lower Westchester Co. NY and pulled back the cover to put in a floating thermometer: surface temp was 60.5F. I also have a sump pump that I can use to circulate some bleach. I'll check chemistries this week.
    Jay--Metro NYC
    35K gal, in-ground, free-form, pebble finish, 2 skimmers, 3 returns, autofill. No spa, no features. Partial shade.
    Pentair C&C cartridge filter (400 sq in), Pentair VS pump, Pentair 140 btu heat pump, Triton Plus Robo-cleaner; Stenner with 55 gal bleach cistern. TFT 100 test kit.
