Results 1 to 18 of 18
Thread: New here and ready to cancel chemical service
    Mar 2016
    Tucson
    6
    Hi all,
    Thanks to this site I've learned a lot and I'm ready to cancel our weekly chemical service. We need to save $ plus I now have the time to take care of it myself. He typically dumps a canister of chlorine (gas?) and some white powder in during his short visit. I plan to see him once more next week to say thanks and see if he has any tips for me.
    Here's the first numbers from my new TF-100 kit.
    PH 7.2
    FC 7
    CC 0
    CH 1200
    TA 70
    CYA 40
    A few days ago I deep cleaned the sand filter and couldn't believe what came out of there. I haven't bought any chemicals yet but it sounds like a trip to Walmart for bleach is a good start.
    David
    Pool - IG Oval 15500 gallon gunite/plaster built 1977
    Single speed ?HP pump, Triton II TR-60 sand filter
    TF-100 Test Kit just purchased
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: New here and ready to cancel chemical service
    Hi Desertdog,
    Welcome to TFP!
    You've done the right thing by getting your own test kit. Thats the first step.
    By the numbers you posted, you don't need any more chemicals.
    your CH measurement of 1200 is high man.. way high. Any chance it would be testing error? Maybe test it again?
    I would recommend you also test your Tap water for CH and see what it is.
    Divin Dave,
    Jun 2014
    15,211
    Welcome to the site. Oh boy, something tells me that between Tucson's hard water and all the junk added in the past from the pool service, that 1200 reading might be close. Experimenting in the Poolmath Calculator, I can see your CSI is right on the outside (high) end. Still you're hanging in there. It's amazing how much a difference even a new TA of 60 versus 70 does for your CSI reading. If you confirm that your CH testing was accurate, definitely use the calculator (very) often to watch pH and TA very closely as they are your last line of defense against that high CH.
    In any case, David .... welcome to TFP. You've done well so far. Glad to have you aboard.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP! Nice work so far!
    Aug 2014
    Northern IL
    4,615
    I would just add that usually you just need to use a 10ml sample for FC/CC and then multiple by 0.5. That CH? Yikes!
    Last edited by MarianParoo; 03-10-2016 at 11:13 PM. Reason: Brain dead... And too many beers
    Mar 2016
    Tucson
    6
    Thanks guys, I'll be re-checking the CH this weekend.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,048
    Quote Originally Posted by Desertdog View Post
    If you don;t have a speedstir, get one. It makes a huge difference in the CH test when you have to mix that many drops. My CH reading dropped 200 points when I switched to the speedstir. TFTestkits.net
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I've seen my CH readings that high and higher. You can't just drink Tucson water, it's got to be chewed. It only takes a couple years to get to those levels, then it's drain and start over (with CH only in the 600-800 range).
    chiefwej
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    CH isnt surprising. hard water plus high temps and low humidity mean lots of evaporation and refills. good combination to get your CH rising really fast. manageable, just keep an eye on the CSI ratio in pool math to make sure you dont start to precipitate.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Agreed, the CH could easily be 1200, but it absolutely should be confirmed with a re test, and makeup water test. Almost two years in, I'm knocking on the 1000 PPM CH door. Not bad though considering I have 700 or so in my makeup.
    Essential Links:
    Mar 2016
    Tucson
    6
    I'm taking the advice on the speedstir and will retest the CH when it comes. For now I thanked the pool man and cancelled the chem service. He dropped in a tank of chlorine and some sodium bicarb, said the bicarb made acid to keep ph low. That seems backwards to me. Isn't bicarb a base? I always assumed the powder he was adding was dry acid. Anyway I'll touch back with new test results in a few days. Thanks again.
    Jun 2014
    15,211
    Typically, sodium bicarbonate is used mainly to raise TA. It has a small effect on pH, but mostly TA. From a previous post:
    Sodium hydrogen carbonate is a synonym for sodium bicarbonate and is the same thing as baking soda.
    Still, here is a very interesting article on its use during plaster start-up: The Bicarb Start-up and Why it Works
    Mar 2016
    Tucson
    6
    Well you guys were right about the speedstir, CH tested at 1050 instead of 1200. A little help anyway.
    Jun 2014
    15,211
    Every little bit helps. But you're right on the edge. Keep an eye on the pH and TA, making sure they remain low enough to counter-balance that high CH (and CSI level) in the Poolmath Calculator. The calculator is your most important tool at the moment. Make sure you update the temperature on that thing as well. It has a big effect on your CSI. Let us know if you have any questions. Good luck!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey Desertdog,
    If he said that about the BiCarb, it's a good thing you let him go. That's scary if he believes that, and carries around Gas Chlorine, but that's what I'm most curious about. You mean to say he left a Cylinder of Chlorine gas at your residence?
    And has he returned to retrieve it? Nothing wrong with Gas treatment at all, but that sounds pretty negligent. In all honesty it would be my first choice for a Chlorine source except for a host of handling issues and red tape hurdles. But wow that is amazing he would leave it like that.
    Essential Links:
    Mar 2016
    Tucson
    6
    Sorry if I mislead you Patrick, he emptied a canister of chlorine into the pool last week and some powder. He didn't leave anything. He may have just told me something about the powder to end the conversation. I had already told him I was cancelling. Good timing too I received a notice of rate increase the next day.
    Thanks again,
    DDog
    Jan 2014
    Buckeye AZ
    807
    how long did it take the CH to get over 1000? IOW, do you know when the last time the pool was drained (if ever)?
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Quote Originally Posted by desertdog View Post
    sorry if i mislead you patrick, he emptied a canister of chlorine into the pool last week and some powder. He didn't leave anything. He may have just told me something about the powder to end the conversation. I had already told him i was cancelling. Good timing too i received a notice of rate increase the next day.
    Thanks again,
    ddog
    haha -- perfect!!
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
