Results 1 to 9 of 9
Thread: BBQ Island Kitchen and Bar Table Build
    Sep 2015
    sacramento
    7
    Thanks to everyone that answered my questions and to everyone on this board that has shared ideas and knowledge. I've been working on my islands - one 12ft kitchen and one 12ft bar table with fire pit. For the bases, I used 20ga 3 5/8 steel from Calply and the bar countertop I used 20ga 2.5inch steel. I'm still working on the framing, but have most of it done. I plan on using Durock all over then then porcelain tile for the counter. The fire pit is 36" long and the parts for that should arrive tomorrow.
    Here's the kitchen section that will hold my 6-burner Summit (shelves removed), smokey mountain, and Lion ice bin (not pictured) on the far end right. I will also be using the side burner from the summit (not pictured).
    Here's the bar height island so far. The 36" long fire pit will be in the middle of the center section. I doubled up the beams all across the counter using a stud inside the track steel.
    I hope to be able to get this completed by Easter.
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Re: BBQ Island Kitchen and Bar Table Build
    That looks grand. All that steel is pretty to look at too, and it looks like you are doing a good job. Did that require any welding or cutting? Are you going to fasten the islands to the concrete? If so, how? Projects like this always make me think I need to hire someone to do it for me. Which is why I don't have nice things Oh and the (bamboo?) fence looks great.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    Sep 2015
    sacramento
    7
    The steel came in 8ft and 10ft lengths, so there was a lot of cutting. I used some Wiss brand shears and the cuts weren't bad, just a lot of them. I didn't weld anything. I do plan on attaching it to the concrete soon.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    Wow! Looking good!
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    I like it! Keep posting updates.
    plat.
    Modern Geometric-ish Social Pool (4'-5'-4') ~13' x 47'. Sun shelf. Perimeter overflow spa. RiverFlow Swimjet. Dog ramp. "Bubble Lounge"
    Link to my patio build, completed 2013
    Link to my pool build, Aug '15 - Sep '16
    Sep 2015
    sacramento
    7
    The project done and came out great. I finished the bases with Dryvit (Mojave finish). This stuff comes in 5 gallon buckets and covers about 120 sq ft. You use a trowel and it give a nice stucco finish. Also, if you are building, get a Pactool Snipper Shear to cut the cement board. Without it, you will lose your mind snapping and scoring or giving yourself cancer by grind cutting it. I was able to get used one for $120 on CL. Best money I spent on this project.
    Here are the pics!
    http://s911.photobucket.com/user/Rem...nd%20Bar/story
    Jun 2014
    15,121
    That is nice! Wonderful work.
    Nectarologist's Avatar
    Apr 2015
    New York
    427
    Looks great! Definitely something to be proud of.
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    Feb 2015
    California
    19
    Looks good! We used the Dryvit Ameristone, and sprayed it. Very nice professional finish look.
