Page 1 of 3 123 LastLast
Results 1 to 20 of 55
Thread: New liner pool outside of Boston, FINALLY!!
    May 2013
    Needham, MA
    140
    I would first like to start out by saying how happy I am to finally be able to start a thread on our pool's construction! This has been years in the making. Just met with the builder and they will break ground in 3 weeks, and we just got approved by the town for all of our permits. Our pool will not be large, but will be perfect for us.
    I will follow up with many pictures of the process along the way. Here is our story with pics to get you started.
    This was a project that needed to be done is phases. We have a small lot, and there is a 6 foot elevation change from one end to the other. The previous owner had built a wood retaining wall, and had an older fence around the yard. However he had done all the work himself and did not pay any regard to property lines or codes. It all needed to come out, and be redone to support the pool and adhere to town code. We also needed to re route and add more drainage from our roof. The grade was also going to be lowered so the new wall didn't have to be erected so high per the town. Phase 1 was started late summer of 2015, and was completed in October.
    Lot prior to any work being done:
    Tree removal, fence removal, and retaining wall removal.
    Building the new wall, and lowering the grade.
    New drywell to support gutters.
    New fence was put in.
    It does not look like it from the pictures, but we did gain a lot more yard then we had before. Still, with the small size plot and the town setbacks, we are forced to go with a smaller pool. It will be a 14x28 kidney shaped liner pool. Below is the initial concept, which we have amended, and then the current CAD plans. I apologize for the low quality of these images. Instead of the fire pit we are putting in a pergola, and we are tearing out the old patio and replacing with grass. The pool shaped changed from the original figure 8 to a kidney to maximize sq footage. The coping will be pavers and natural stone, while the patio will be paver. We will also be updating the steps from the house down to the pool deck.
    Excited and nervous to finally begin the adventure. After much time spent reading through countless posts on this site, I feel confident that we made a lot of good decisions. I look forward to updating with more pics along the way.
    14x28 Kidney IG vinyl pool, 9250 gallons. Pentair 1.5hp superflo variable speed, Pentair Clean and Clear 240 Cartridge filter, Pentair IC40 SWCG, Hayward Heatpro 110,000k heat pump, Pentair Intellibrite 5G LED lights, Polaris 280, Taylor K-2006 test kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,572
    Re: New liner pool outside of Boston, FINALLY!!
    WOW! What an adventure you are on! Just to get your lot set up was some kind of work! Who puts up a fence and does NOT check the property line???? OUCH! Good job on your set up!
    I love the design of the pool and the area. That is going to be nice when it is done!
    Kim
    May 2013
    Needham, MA
    140
    Quote Originally Posted by kimkats View Post
    Kim
    Thank you! We are excited and nervous all at the same time. Nervous because we just want the build to go smooth. Again, this site has been such a wealth of knowledge I really cannot thank everyone enough. Looking forward to this summer for sure, and I am sure I will have more questions for you all.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Congrats on the new pool!
    Aug 2014
    Northern IL
    4,615
    Woot! Looks great!!!
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    I like how you've squeezed so much function out of your space!
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Aug 2014
    Houston tx
    2,525
    I totally get the excited and nervous part!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    May 2013
    Needham, MA
    140
    So progress continues this way. We have signed off on our liner choice, "The Regatta", and have signed off on the final shape. Both the liner and polymer panels have been ordered. Once received they will start digging. Hoping this is within the next couple of weeks.
    Final grading of the yard has begun, as has ripping out the old patio.
    FInal pool shape:
    Liner "The Regatta"
    Jul 2012
    Tallahassee, FL
    30,572
    LOTS of swimming space! NICE pick of pool and liner!
    Kim
    May 2013
    Needham, MA
    140
    So as it turns out we were not done as we thought on agreeing to the final shape and depth. The plans listed above were for panels that were 42" tall, but we wanted a shallow end of 3'6" so the panels need to be 48" tall. They sent out new plans for me to sign off on, but with this set of plans they now included where the slope starts, and pool depths. Wanted some opinions on this. Our pool is not very long in total length. I feel the shallow end is longer than I would want, followed by a slope moving to the deep end rather quickly in the grand scheme of things. As it stands in this set of plans the shallow end is 40% of the pool, followed by the slope which is 25%, then the deep end makes up the remaining 35%. Since the pool is not very long nor deep (3'6"-5') we wanted more of a gradual slope. We have asked the builder to come back with a plan of the pool being split up more evenly, giving us a longer more gradual slope to the deep end. He said they can, but worries as we have little ones that the pool will get too deep too fast. What are your thoughts?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    In my opinion, I like deeper more.
    My current pool begins it's slope about halfway through and I wish it began much sooner and was deeper (only 7 ft in the last 1/4 of the pool in the middle).
    (my last pool was a 9 foot deep diving well, with a very rapid depth from shallow loved it)
    But young kids is a major consideration. As long as life jackets are used and always supervised (as I do) I don't see a problem.
    And once they're grown up it won't be an issue.
    Dolphin E10 Cleaning Robot.
    DFW, TX
    24,502
    We love our play pool. 3'6" is too shallow. Nobody goes there, especially not kids. We would build our next pool 4x5x4. Perfect!
    May 2013
    Needham, MA
    140
    So we made the change and are much happier with the location of where the slope will be starting. This will make the slope more gradual, and will not make the pool as shallow. Builder placed the order today for the panels! Now if the weather would just stay nice they may actually be able to start digging.
    Jul 2012
    Tallahassee, FL
    30,572
    Nice set up! I can't wait to see it!
    Kim
    May 2013
    Needham, MA
    140
    Just got the call last night that our dig day is next Tuesday weather permitting. We are very excited over here!
    Of course as things tend to work out, we will be on vacation week three of the build. Originally we were supposed to have already been way under way, but weather and going back forth on design has backed us up. Needless to say I am not in love with the idea of not being here, but I have been assured that most of the work will be done in the first two weeks as they need to move fast due to my soil conditions.
    We did add a heat pump to our list of equipment. I know here in New England a heat pump will not extend our seem season, but it will take the chill out. My wife and I prefer water temp around 83. No gas line to our house, and the town will not allow for propane where our equipment pad will be setup. I ended up ordering the Hayward Heatpro 110,000 BTU unit from Amazon. It will be delivered next week, and the pool company will install. Much cheaper that route than purchasing the same unit from the pool company.
    Looking forward to the weeks ahead!
    Mar 2016
    Ontario
    3
    How old are the kids?
    Jul 2012
    Tallahassee, FL
    30,572
    Happy news for sure!
    Now if they are on a very important part of the build while you are gone you CAN make them stop and wait until you get back. YOU are the one paying so what you say goes! When the time comes let us know where the build is and we can guide you on if you need to be there or not.
    Kim
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    No worries being out of town. Usually PB's don't do any work on weeks 2, 3, 5-6, 8, 9 and 11! Or some variation of that it seems.
    JK of course, but you can always request him to send you detailed pics so you can approve all work done those days.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2013
    Needham, MA
    140
    Quote Originally Posted by stanshillis View Post
    Kids are toddlers.
    Kim
    Builder sent me payment schedule today. We discussed our being away on vacation. It was agreed that if I wanted them to stop while we are away that would be fine. However, he is still saying that the bulk of things will be done the first two weeks but it is my decision to make.
    Now that this is all finally happening, why am I so nervous?
  20. Back To Top    #20
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    Yay! Excited to see the progress of your pool and to see what your liner looks like when its done! Its one of my top choices.
