Thread: corrosion issues?
    Jul 2013
    North Canton, OH
    192
    corrosion issues?
    I have been thinking of installing a SWG. But I have some lingering concern about corrosion. Specifically, I have steel walls behind the vinyl liner. And I have encapsulated rails below the coping for the Coverstar autocover.
    I think I asked about this before, but I could not find the old thread if I did.
    Should I be concerned?
    Thanks
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    Nov 2011
    Moberly,MO
    1,010
    Re: corrosion issues?
    The steel behind the vinyl will be ok. Where you stand to see an issue is where the skimmer opening is. Your cover track should be ok but the cover mechanism could suffer from the salt. Occasionally you will want to take a hose and rinse off the mechanism to remove the salt residue. I say this assuming it is an all aluminum mechanism.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
