Results 1 to 9 of 9
Thread: Interpreting Results of Salt Test Strips
    Apr 2008
    Suffolk, VA, US
    62
    Hi all, I would like advice on how to read the results of the Aquachek Salt Test Strips that optionally come with the TF100 test kit.
    I have attached an image which shows how my test results look. As you can see, the white streak completely consumes the strip for a ways up, then only partially consumes the strip the rest of the way.
    My question is, do I read the result at A, B, or C?
    [attachment=0:2v84texn]salt_test.JPG[/attachment:2v84texn]
    Thanks!
    Kelly
    Rectangular Vinyl 20' x 40', 3.5' shallow end, 8' deep end, approx 33,000gal
    1.5 HP Pentair WhisperFlo / 60 gal DE Filter / 2 returns - 1 shallow end wall, 1 deep end floor
    SC-60 SWG / Autopilot Digital Pool Pilot v.4.2 / Polaris 280 w/ Booster Pump
    TF-100 Test Kit
    Jun 2007
    Arlington, VA
    29
    Re: Interpreting Results of Salt Test Strips
    A. That's what the instructions say, and that's the reading that matches the output on my SWG.
    ____________
    34,000 gallon pool with charcoal Marquis aggregate finish
    Jandy stealth pump, cartridge filter and Aquapure SWG
    Solar heating with Goldline controller
    Polaris 380 Blackmax
    Apr 2008
    Suffolk, VA, US
    62
    Ok, thanks. I was confused because the picture provided by the instructions do not show an upside-down U shape towards the end of the ****e streak. It simply shows the white part consuming the full width of the test strip.
    I had been using B as my measurement and recalibrated my SWG based on that. Based on this info, I will re-test and recalibrate.
    Thanks again,
    Kelly
    TF-100 Test Kit
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by chazas
    Maybe I missed it - what are you supposed to read then - if not B, then A or C?
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Use A - the upper most tip of the white peak
    Apr 2008
    Suffolk, VA, US
    62
    I've re-tested my salt level, and read the peak of the streak instead of the midpoint.
    I am measuring 5000ppm of salt. I think I may have overdid it at the beginning of the season.
    My autopilot claims to be able to support "special applications" which require high salt. So, I am assuming that this high level of 5000 will not damage my system in any way. I've seen info in the forums suggesting corrosion of pool equipment - do I need to be concerned about that at this level?
    TF-100 Test Kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    There was this recent post by Jason on the "Water Balance for SWG" thread....
    I don't reccommend salt me eps over 5000, but that isn't why some SWGs shut down at 4000, or whatever level. Higher salt levels make the water more conductive and the SWG needs to turn down the voltage to compensate. Many SWGs have a voltage they can't adjust below so they have to shutdown to avoid overheating at high salt levels.
    I don't know much about them, can't help you here. Sorry!
    Apr 2008
    Suffolk, VA, US
    62
    Ooooo! Thanks, this could possibly explain why my SWG volts are running so low. Interesting.
    TF-100 Test Kit
    Corrosion risk grow very slowly up to about 5500 or 6000 and then gets suddenly worse a little above 6000. AutoPilot units are fine at high salt levels, they just lower the voltage as needed.
