Advice needed for replaster using QuartzScapes Caribbean Series - Aruba Sky
Tnrboy
0
Feb 8, 2015
7
Pearland
Hello,
Almost 30 days ago I had my pool replastered with Quartzscapes Caribbean Series Aruba Sky (http://www.nptpool.com/finishes/quartzscapes/quartzscapes-caribbean-series)
Our PB said that I should expect 'marbling effects' / 'slight discoloration'. We talked to NPT and a friend that had a lighter color of Quartzscapes and felt that whatevever happened with the plaster we would be okay with it. NPT said that as long as the recommended pool startup is followed then there should be no marbling. Now, we are at the end of the pool startup phase and want to get a second opinion on how part of the plaster looks.
What do you all think? Have you seen this? Any suggestions on what we can do to make the colors ...more consistant?
Thanks
If you can take a picture with the pump off and the water glassy smooth, it will show the surface better...though it doesn't change the above advice.
This is my quartzscapes finish today. Mine is 5 months old.
This was during the fill. You can see it look uneven in some places.
I forgot to say I brushed mine daily the first couple of month. It took mine a few months to even out. I love mine.
