Results 1 to 18 of 18
Thread: New Build - Corsicana TX
    Feb 2016
    Corsicana, TX
    9
    Heya all!
    I've been reading up and trying to learn as much as I can.
    Unfortunately, I'm a bit late to the game.
    The pool is already in the ground at the gunite stage.
    We're building a new house. Although I have a GC for the house, pretty much every decision has been up to us. So, I've had to learn about every tiny little thing in the house. I've done construction professionally, so some of it was pretty easy, but I guess I never knew how many decisions we had to make. I had to become an expert on dishwashers, hot water heaters, foam insulation, etc. We made structural changes at the last minute so I learned some engineering, etc. I did a lot of the bidding for materials. Building your own house from plans is a lot different than "building" with a tract homebuilder. The GC could have handed me a turn-key house, but he is so accommodating, it was hard not to take advantage of being able to dial things in exactly how we wanted it.
    Anyway, we decided to do the pool in conjunction with the house. There were some obvious advantages to having easy access for the machinery, coordinating with the landscaping, etc. I think we found about as good of a pool builder as was available. After reading some stuff here, I asked him some questions and he hit the right notes, so I felt pretty good. Especially since the contract was already in play.
    Obviously, I would have liked to spend a lot more time researching BEFORE jumping right in, but with all the work on the house, I just had to do as good as I could with what little I knew. I figured a big part was finding a builder with a good rep and having a good feel for the guy. Yeah, when it comes to money, that can come back and bite you, but again, I just didn't have the time to do it perfect.
    So, here I am trying to play catch up. I had him send me a list of equipment he suggested. He is also very accommodating and said if I want to substitute anything, it will just be cost difference, since he has to put it in anyway.
    I've got some pictures I'll post up tomorrow when I get to my home computer.
    Here's the list of equipment. We've got money available if there are some items we just NEED to upgrade or change.
    Zodiac---
    JS-100SM Sand Filter
    BWVL multiport valve
    1.5HP 2 Speed Pump
    2.5HP Single Speed Pump
    PB-460 cleaner booster pump
    Polaris 280 Cleaner
    Intermatic 2 Speed PE 25300F Timer
    CD40 Ozone System
    Rainbow 320 Chlorine Feeder
    Nature Express Mineral Sanitizer
    OR
    TrueClean 11k
    Raypak 013315 Heat/Chiller
    The pool is 15x30 with a negative edge.
    Thanks for any insights!
    --Trick414
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Re: New Build - Corsicana TX
    Welcome!
    What a great view! A negative edge is going to be fabulous in your setting!
    Around here, not much is thought of the ozone thing or pressure side cleaners that require an extra pump. You'd be better off going with a robot and SWG.
    I'm sure the experts will be along shortly but these are the things I see right off the bat.
    Congrats on the house and the pool! Post up lots of pictures! We love pictures!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Welcome! Awesome view with the angry water in that pic. I think there are several items to suggest or think about on the equipment.
    - Consider removing the booster pump and pressure cleaner and going with a robot. Almost a no-brainer these days. I should have.
    - A sand filter is fine. Easy to backwash but uses water to do so. DE filters beat but backwashing or cleaning requires care in some locations due to DE disposal requirements. Cartridges filter in the middle and will need to be rinsed but use less water to do so and there are no disposal issues. All three filter satisfactorily. The only time you may notice a difference is at night with lights on. A few more floaties with sand perhaps. But go big regardless.
    - You will want to ditch the mineral system (adds metals to water which stain) and ozone (completely not needed - look up at el sol). You can keep the inline chlorinator but will only use it on occasion, not routinely. Your chlorination should come from bleach or a salt water chlorine generator. Both about the same cost in the long run.
    - Automation is a great place to spend some upgrade dollars if you wish. Though for a pool with no spa, it's not as critical. I however love our automation and have no spa or water features.
    - Huge consideration is plaster surface material. Good luck with that one! Reading a few builds will give you the sense that it's one of the hardest decisions to make
    I enjoyed reading your rationale for not being able to get into more pool details from the beginning and could completely understand. Sounds like you made the best of it and now can address the rest.
    Best of luck.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Feb 2016
    Corsicana, TX
    9
    Thanks for the replies so far.
    He stated he was going to do the TruClear11k SWG, not sure why he had the options for the ozone and mineral stuff. Maybe just in case I wanted to go that route???
    We talked about the robot. Should I ditch the pump altogether, or leave it as a secondary system?
    He has assigned the plaster project to us. I'll let my wife handle that. The grand extent of my input will be "blue". And all blues look the same to me.
    Thanks!
    --Trick414
    Aug 2014
    Houston tx
    2,525
    Yes, definitely ditch the ozone and mineral sanitizer. You only need liquid chlorine (bleach) or a salt water chlorine generator to sanitize your pool. You could probably get rid of the inline feeder (they use tabs which causes the CYA to rise- not good!).
    Make sure your equipment is all one brand. That way you may get better warranty coverage and not all brands play well with other brands.
    Oh, and welcome to TFP!!!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Feb 2016
    Corsicana, TX
    9
    Oh, a couple of other things.
    We talked about a variable speed pump. He said it was a good idea if I wanted to get down in the nitty-gritty and dial it in. He said the 2 speed was a bit easier.
    After what I've been learning here, I'm pretty sure I'm going to break out my HS and college chemistry and go full OCD on it. So, maybe the VS pump is a good idea? I think it will just cost me a few hundred dollars.
    Also, in case it might matter, we also got a motorized cover for it. I don't know how much that will change any equations We will probably keep it covered most of the time since we don't have to have a fence.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    I would spend a little extra on the VS pump. Everyone here who has one loves them, including me! Managing your water seems like a big thing at first and all that reading seems like a lot of stuff. I definitely had to read it all 20 or 30 times. But, it is really pretty simple and definitely easy. Start here, Pool School - ABCs of Pool Water Chemistry
    Covering the pool will make things a little simpler. Less evaporation and less chlorine usage.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Everyone ^^^^^^^^ has you on the right track. my input will be tell your wife she is welcome to use your account and ask us about the finishes she is thinking about. Has she picked out the waterline tile yet?
    For you I suggest you go ahead and order your test kit. That way you can test your fill water and know what you need to have on hand to balance your water. Look in my siggy for the test we use and love.
    With you being right there on the water I THINK you would not want a DE filter as some places frown on it being dumped near bodies of water.
    Kim
    Feb 2016
    Corsicana, TX
    9
    Again, thanks for all the replies!
    I have been going through the Pool School and trying to soak up as much as I can. I'm a member of several other similar forums for other interests in my life. It's amazing what you can learn just "hanging out" with like-minded folks. Absolutely amazing.
    Anyway, here's a few more pictures:
    Feb 2016
    Corsicana, TX
    9
    Heya all!
    Just a quick update. The pool is pretty much done other than the plaster. We are just waiting on all the landscaping to finish up to do the plaster.
    We changed out the pump to variable speed. I'll add in the robot cleaner later after we get going and I get up to speed.
    Aug 2014
    Houston tx
    2,525
    Wow! That's a great looking pool!
    Marla
    Feb 2016
    Corsicana, TX
    9
    So, we still have some landscaping to do. But, they fired up the pool. It will be another few weeks until we move in, so I still don't know much about it. But, I'm getting really excited.
    Jul 2012
    Tallahassee, FL
    30,585
    Pretty! Can't wait to see you in it and the house!
    Kim
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Wow that's a nice pool. Would love to see a pic of the negative edge with front view so that it blends straight across with the waterway. Good luck with the pool and the landscaping. My pool is not filled yet but I started the perimeter landscaping.
    I thought of a negative edge for my pool as I have a lake in back but wouldn't have worked as well as yours because I have a screen and the lake is set back far with a wilderness shoreline. So I went with sheer waterfalls instead.
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
    Feb 2016
    Corsicana, TX
    9
    I'll have some more pics up tomorrow.
    They are dressing out the sides with stone and more marble and installing the cover.
    Thanks!
    Greg
    Feb 2016
    Corsicana, TX
    9
    Ok, I'm finally back with a few more pics (although nothing really new) and some water numbers.
    Unfortunately, we are still waiting on landscaping. What a nightmare. I love living in the country now, but the laid-back country way of life can be a bit excessive at times.
    Anyway, here's a few pics:
    Feb 2016
    Corsicana, TX
    9
    The current water has only been in about 3 weeks. We had to drain and fix the LED lights.
    The SWG is running with the filter pump, about 8 hours per day at 1750 RPM. It's a VS pump, and the SWG is set at 90% chlorination right now.
    The booster pump is gone, and I'm waiting on my 9550 robot cleaner. I've been using a pole mounted garden hose vacuum thing to suck up the debris for now.
    I got my test kit from TF Test a few days ago and finally got around to testing. I had picked up a test kit from Home Depot last week as well.
    Anyway, here is what I had this morning:
    Salt - 1600 ppm
    pH - 8.0
    FC - 1
    CC - 0
    CH - 150 ppm
    TA - 80
    CYA - less than 20, beyond the range for measuring
    I put in 120 pounds of salt this morning and got my salt up to about 3200 ppm.
    I think the SWG might be set too high at 90% for 8 hours?
    I'll add my equipment to my signature when I find the setting, but here it is:
    Jandy VSFloPro pump (2HP at 1.35 S.F. for 2.7HP) - filter pump
    Jandy Stealth pump (2.5HP at 1.93 S.F. for 2.6HP) - overflow pit pump - this thing will move some water when I turn it on!
    Pro Series 11P SWG controller and TruClear 11K SWG
    Some type of Zodiac pump controller, I'll have to dig out the specs
    Sand filter of some sort, maybe the one listed above in the first post, I'll confirm later
    I think some tweaking to the pump and SWG settings are in order, and some minor chemicals to get the pH, CYA, and TA where we need them?
    Thanks for any help!!
    Jul 2012
    Tallahassee, FL
    30,585
    I have a set of links I share with new pool owners. It is a lot of info. but it will all make sense as you use it. I hope these helps.
    Here are some links you will need when you are starting up a pool.
    Print these out:
    Bookmark these:
    http://www.troublefreepool.com/calc.html
    Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
