The POOL circuit should be your main filter schedule, SWG run time, and the lowest speed you want your pump to run.
In ScreenLogic, the POOL circuit should be assigned to POOL for Circuit Function assign POOL, set the RPM to 1250, Check Chlorinator present
If you want a POOL HIGH circuit, select an empty Feature, set the name to POOL HIGH, circuit function Generic, set the speed to 3000.
Find the Aux Circuit that your lights are wired to and set the name to POOL Light, Circuit Function IntelliBrite
Feature circuits are basically alternate pumps speeds that you can program. All they will be able to do is change the pump speed until you get some valve actuators.
An Aux Circuit is connected each one of your relays and they function as a switch that the automation will turn on and off for you. Your pool lights and landscape lights are examples of Aux Circuits.
