Thread: PAL Pool Light Commander Timer
    Feb 2016
    Charlotte
    2
    I have the PAL 42-PCR-8A (non wi-fi version) hooked up to two LED lights in the pool. is there a way to hook a timer to this somehow to have the lights come on and off at predetermined times? i know i can add the WiFi module but not sure that really helps.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: PAL Pool Light Commander Timer
    Welcome to the forum!
    Sorry you haven't had an answer, but hopefully a bump to your post will get it visible to someone who can help. Good luck in your search.
    Essential Links:
    Feb 2016
    Charlotte
    2
    I went ahead and wired in a timer before the electrical connection to the PAL control box. If the light is set to on and then the electricity is cut, when electricity comes back on the light also comes back on. This essentially allows the entire system to be put on a basic timer. The only limitation is the light comes back on always on the “white” setting, which for me was perfectly fine.
