Results 1 to 19 of 19
Thread: Pool Shell Mis-Measurement
    Nov 2015
    FL
    3
    Hello there TFPers. Long time lurker, first time poster and pool owner. Quickly to the point, and I will maybe provide pictures of entire build later.
    There was a mis-measurement in our pool shell construction that did not make itself apparent until the coping was installed. This mis-measurement resulted in a supposed right angle in the pool construction, not being square.
    Pool Construction is complete now, of course pool builder claimed they couldn't even notice it. We have not yet remitted final payment, we just filled the pool Monday 3/7.
    What advice do you have, as a group, on this matter? Is this just something one must accept as acceptable wiggle room in construction, or should a big deal be made of this? I was advised by the pool builders sub, that "they aren't building a piano here". Please offer your opinions.
    Picutres attached, Thanks.
    Sep 2015
    Dallas Texas
    53
    Re: Pool Shell Mis-Measurement
    At minimum, I'd inform them a portion of the final payment will be waived due to the issue. Overall, I wouldn't want the hassle of ripping up concrete, etc, for a relatively minor issue
    Fiberglass pool 5300 gallons (trilogy eclipse)
    inground
    Cartridge filter
    2HP hayward ecostar sp3400vsp
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    I have a rectangular pool. When they were here to spray it out and do the dig, they spent a LONG time measuring because my PB said with geometric shapes you have to get them perfect. They spent 1/2hour just working out a 3/8" difference.
    I'm grateful for their care in making sure everything is square and plumb.
    You should definitely not just accept the way they did this, in my opinion. You paid a lot of money for a quality job and this is just sloppy measuring.
    What you should do about it, I don't know. If it were me, that difference shown in the pictures would bug me greatly. I guess it all depends on whether or not you can live with looking at it like that every day.
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Jun 2015
    Mandeville, LA
    109
    Seems like they could have fudged that coping a bit and made it a whole lot less noticeable.
    Completed April 2016: 22x36 3.5-5.5-4 Inground, 17,500 gallons, Aquapure SWG, Jandy 2hp Variable Speed, Jandy 460 Cartridge Filter, Polaris 280, Aqualink PDA4, Jandy Nichless LED lights, Diamondbrite color Steel Blue, Noche Travertine Coping & Deck
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    Quote Originally Posted by WyattEarp View Post
    That is what I was thinking as well. See if they can/will redo the coping with the off square part in mind.
    Kim
    Apr 2013
    Sacramento, CA
    2,769
    How much is it off? 1/2 inch? 1/4 inch? Most residential pools are within a 1/2 to 1/4 inch of square after plaster. It looks like yours is also. You are talking about a cut in which makes it much more difficult to square up the pool. Frankly in a battle in court you would lose. That is within industry standards. I doubt most pool builders and gunite crews could get it better than what you have. In Florida with all the heat and humidity I doubt one could get it better than that. Its not getting it perfect, its getting it built so it looks perfect.
    I would tell them to redo the coping and the pavers to make the problem less noticeable. That is where the problem is. There are several ways to fix that so you would not see it. The gunite sub is supposed to get it square and the plaster sub will try and make it better if they can. But the cut in makes it very very difficult to square up in the field.
    Which sub made the piano comment? The pavers sub?
    Jan 2016
    Mesa, Az
    541
    Exactly what I was thinking. Sloppy and lazy . . .
    Nov 2015
    FL
    3
    Thank you all for replying. It was the coping contractor, that made the comment about accepting some deviation. Frankly, the rest of the build went so well, it's a shame that this eye catching discrepancy occurred.
    So the question really is; am I within my rights as a consumer to demand/request/expect anything of/from the builder, or am I simply at their mercy?
    Thanks for your frank response gwegan. If I am being overly picky, I would like to be told that honestly as well, it just sucks paying out the nose for a project and it not coming out perfectly.
    Apr 2013
    Sacramento, CA
    2,769
    I would tell the contractor to redo that area of the coping and pavers. The paver coping sub should have made this disappear.
    Indigo blue's Avatar
    Apr 2015
    Boca Raton, FL
    216
    Agree with everyone here... This can be fixed with cutting the coping to appear straight
    Just as a curiosity, where in Florida are you? So am I. I love the color of your water, what did you use? and congratulations on your new pool, after you get this done it will be like it never happened and you'll enjoy your pool for years to come.
    13k gallon 10x35 IG salt water pool 8x10 spa Hayward ecostar variable speed pump with remote. Diamond Brite cobalt. Diamond brite watercolors
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Also want to know what your plaster color is! And wouldn't mind a picture of your whole pool. Keep us posted and let us know how they resolve this for you.
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Nov 2015
    FL
    3
    Plaster Color is Pebble Sheen Blue Granite. Looks awesome. Will post full build after this issue is resolved. Stay tuned.
    Thank you all for your input.
    30,426
    I would leave it alone. You have a nice looking tile job and I had to look three times at the picture to see what you are talking about. If you demand perfection, your tile guy may walk away and your dealings with PB can quickly become acrimonious. Be careful what you wish for.
    I know I sound harsh but I am familiar with pool construction and particularly laying tile........I would say that work was acceptable.
    Aug 2014
    Houston tx
    2,524
    Duraleigh, I thought it was my old eyes that couldn't see it! Well, maybe it is (ha!), but without seeing a picture of the whole pool or at least more of the area to see how it looks overall, I would agree with you.
    Marla (who had her tile people recut a mitered corner because the joint wasn't straight)
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jan 2016
    Mesa, Az
    541
    I disagree. Now that you know it is there, it will be a constant sore spot with you for the life of the pool. Either get them to fix it or pay to have someone else fix it, but save yourself the ongoing aggravation and get it fixed.
    Aug 2015
    Cypress
    1,679
    I could see it but had to look. I'm OCD and a big mistake would bother me but the pictures didn't show enough of the pool to fully see the problem. Can you post a picture from a wider angle and a more distant look at the problem?
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    I can't discern the problem, lol. Put a potted plant on it!
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    I'm with Big D., call it a quirk and enjoy the quality stone work - if slightly out of square (honestly I barely see it). It could be fixed perhaps but you know what you have now.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2015
    Fullerton, CA
    636
    yep that would bug me, I am also OCD, but then sometimes the fix causes more issues. I have the same type of issues like that. some we are fixing some I am just going to deal with. The sad truth is it's really hard to find quality contractors, and it's nearly impossible to find quality contractors who are also OCD about the details. If it bothers you inquire about the fix. If they can do it without causing other damage then go for it. Sometimes it's just easier to live with it if you are going to open a can of worms. Our build has run into a lot of issues, some we had fixed, other I will just have to ignore and have another drink, lol.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
