Thread: Do you leave your waterfall on when running pump?
    Sep 2015
    Dallas Texas
    53
    Does it make sense to keep the waterfall on every time the pump is running to clean the pool (8 hours a day) or do you only use it when you're using the pool/in the backyard?
    Fiberglass pool 5300 gallons (trilogy eclipse)
    inground
    Cartridge filter
    2HP hayward ecostar sp3400vsp
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,467
    Re: Do you leave your waterfall on when running pump?
    Meaty,
    Constant use of a waterfall will most likely drive your pH up pretty quickly. For me, I usually only fire up the waterfall when the "ambiance" is important. Most of the time the waterfall is turned off. Although, I do have it scheduled to come on everyday for about 10 minutes just to make sure the water in the pipes stays chlorinated.
    Sep 2015
    Dallas Texas
    53
    Quote Originally Posted by Jimrahbe View Post
    Meaty,
    thanks. That was my concern
    inground
    Cartridge filter
    JoyfulNoise's Avatar
    May 2015
    13,180
    My waterfall has basins in it (four basins that hold anywhere from 2 to 4 gallons each). I have to run my waterfall about three times per day for about 20mins each time. This keeps the water in the basins chlorinated. In the winter, I "close" the waterfall by shutting down and draining the pump as well as suctioning the supply line dry. I do that because the waterfall pump will run with the freeze protection circuit and it's a huge 3HP WhisperFlo that uses A LOT of electricity.
    Matt
    Killer95Stang's Avatar
    Sunny SoCal
    591
    5 minutes every other day on a set schedule, and then only when we have friends over.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
