Thread: Replacing SuperFlo 1 speed motor w/ 2 speed
    Jun 2012
    Woolwich Twp, NJ
    7
    I would like to replace the motor on my SuperFlo 1.5 HP single speed (340039) with a 2 speed motor.
    Is the Pentair 356630S motor the correct motor?
    Do I use the same impeller?
    Which gaskets should I replace when I perform the swap?
    Thank you for any help.
    30K gallon free form vinyl IG pool with waterfall
    Hayward DE3620, Pentair Superflo 1.5 HP
    Dolphin Nautilus
    4 returns, 2 skimmers, 1 bottom drain
    1.5 inch plumbing
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Replacing SuperFlo 1 speed motor w/ 2 speed
    You could get a Pentair motor but it would probably cost you a lot more. The B2982 motor is direct replacement as well.
    Yes, you can keep the same impeller unless you want to downsize the pump.
    You want a SuperFlo Go-Kit. Amazon.com: Pentair SuperFlo Garden
    Mark
