Thread: Replacement Pump
    Replacement Pump
    I am new here , so I hope this question is in the correct area I own a pool and need to replace one of my pumps. The sticker on the pump reads LR51044 it is a polaris PB4 booster pump. The pump lasted about 5 years which I think is pretty good. My question is does anyone have any comments on this pump and/or suggestions on where to purchase. Thank You
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a sand filter=300 lbs of sand
    vinyl liner
    Feb 2008
    Denton, TX
    5,061
    Re: Replacement Pump
    Welcome to TFP!
    Why do you need to replace it? Sometimes there is a simple and money-saving solution to pump problems. What is it doing (or not doing)?
    i also have the pb4 booster pump Lr51044 and i dont believe it is sucking the dirt out what should i do replace it or can it be worked on?
