Results 1 to 9 of 9
Thread: So many fitting color choices??
    Woodp721's Avatar
    Jun 2015
    Carrollton, Tx
    38
    When they came to shoot the Stonescape Aqua White surface they had Black, white, Tan, and fittings.
    They started putting black in and I stopped them and had white put in. They said black is the new color? Really? After, I found out there is a gray too...I'd of love the gray. Anyone want to weight in on this? Maybe I'm just to new to all the color choices.
    Woodp721
    15K gal. 12X80 plaster-stonescape aqua white, buff leuders coping, Verona Borba Turquoise w/Borba Turquoise Deco
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Re: So many fitting color choices??
    I'm pretty sure I wouldn't want black on white. I would have wanted something that would blend nicely. White or maybe gray for sure!!
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    I'm getting Tropics Blue minipebble and going with light grey. I bet that would look nice with your aqua white... Way better than black at least!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Feb 2016
    Houston
    323
    What are fittings? Is Stonescape like Pebbletec?
    JamieP's Avatar
    May 2011
    1,135
    Yes, Stonescapes is NPT's version of Pebble.
    Fittings are the things that are attached to the pipes that enter the pool shell, like returns, vacuum lines and autofill lines. They make lots of different styles and colors to do different jobs.
    Feb 2016
    Houston
    323
    Quote Originally Posted by JamieP View Post
    Thank you. Still learning. Our PB1 is offering Stonescapes mini pebble white or salt and pepper as an upgrade over 4 basic colors of Quartzscapes.
    I agree that a more neutral color would look better than black. I will now keep in mind that I may have a choice of color on the fittings.
    Woodp721's Avatar
    Jun 2015
    Carrollton, Tx
    38
    Yes, Stonescape is like Pebbletec but a smother finish.
    Woodp721
    Feb 2016
    Houston
    323
    Quote Originally Posted by Woodp721 View Post
    Good to know. Pebbletec is better than Quartzscape, but we were worried about the rough finish. If Stonescape is smoother we will consider it over the Quartzscape. Do you have a thread on your pool build with photos of your finish?
    My pool thread. IG 31' x 20', 3.5'/4.5'/6', 8' spa, 4T moss rock WF/WW w/jumping rock, 7' x 11' sunshelf 3 bubblers, travertine coping, spray deck, Hayward equip: SwimClear 525 Cartridge Filter, H400 natural gas heater, Tristar Dual Speed EE pump 2HP, Tristar EE pump 1.5HP for water features, blower 2HP, Prologic P/S 8 w/aqua pod remote, Aqua Rite T-15 Salt System, Tigershark QC robot, networked Colorlogic LEDs 2 pool 1 spa.
    JamieP's Avatar
    May 2011
    1,135
    Stonescapes has different sized pebbles, regular and mini. The mini pebble of stonescapes is comparable to Pebble Sheen, and their regular pebble is comparable to Pebble Tech. At least that's my understanding.
    Gemstone makes a really fine pebble, called a micro pebble, that's even smaller than the mini mentioned above. You can get it with or without glass. You might check them out if you can. Nursenini is getting it in her pool soon. With the glass it's called Radiant Fusion and is very smooth.
