Thread: First Fill (almost) Aqua White Stonescape Color!
    Woodp721's Avatar
    Jun 2015
    Carrollton, Tx
    38
    It’s raining and will continue all week. Tomorrowthe PB will start adding the acid to brush the pool. He says the surface colorwill become bluer as it’s brushed daily.
    Woodp721
    15K gal. 12X80 plaster-stonescape aqua white, buff leuders coping, Verona Borba Turquoise w/Borba Turquoise Deco
    Jun 2014
    15,212
    Re: First Fill (almost) Aqua White Stonescape Color!
    That's great. Exciting times, and we needed some rain. You will most certainly follow your PB's advice to keep in-line with the warranty. But also refer to the Pool School - Start-up New Plaster page to compare notes and keep yourself armed with any questions you may need to ask. Enjoy!
    Woodp721's Avatar
    Jun 2015
    Carrollton, Tx
    38
    Thank you, I appreciate your help.
    Woodp721
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Congrats! Heckuva storm we had today! Yes the water out of the tap is surprisingly green. It will get a lot better in a few days. Be sure to keep your PH at 7.8 or less, test every couple of days until you understand how the pool acts. After the PB is finished with their part be prepared to add muriatic acid pretty regularly for a while.
    Nov 2015
    Woodland Hills, CA
    176
    Can you take/post some more pictures please???
    thanks in advance,
    O/B Woodland Hills, CA : O/B12x30 inground with 6x6 10-jet spa, 10,500gal, 6' Baja deck, 42" spillway, All Jandy: 400k heater, 2.7 HP VS pump, 1.5HP booster spa pump, SWG, Intellelink controls, (4) LED lights, cartridge filter and BlueSquareQ360 infloor cleaning system, Eclipse drain, glass tiles, Zanzibar white pebble finish. Broke ground 2/18/2016, completed 8/16/2016. TFT 100 kit.
    yes, more pictures please. very interested to see you Aqua White pool
