Thread: Pool access gates
    May 2015
    Fullerton, CA
    635
    Pool access gates
    Need to get the new gate installed for pre plaster inspection. Think we will go a tubular steel gate, 4ft wide 63" tall. I know it must open outward and be self closing. I also think the latch must be 54" off the ground, I am guessing a doorknob will not work here unless it's mounted 54" high.
    Thx
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Pool access gates
    Although you live in Fulterton these are LA County's requirements: https://dpw.lacounty.gov/bsd/lib/fp/...%201-11-13.pdf
    The requirements should be the same. And no a doornob will not work unless it is more than 54" high. It can be less but then there must be another self closing latch more than 54"
    Killer95Stang's Avatar
    Sunny SoCal
    591
    A standard gate latch mounted at 54 inches will meat the requirement.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    I have a wrought-iron gate to my yard. There's a standard deadbolt at standard height and a gate latch at the very top that is just barely reachable by reaching over. The string broke and I never replaced it. There's a spring by the hinge. So it's self-closing and it has a latch too high for children and it's also lockable but easy to unlock from the outside. A padlock in the gate latch wouldn't be easy from outside. Hope that helps you plan.
    May 2015
    Fullerton, CA
    635
    thank you!
