Results 1 to 7 of 7
Thread: Unscented/regular scent bleach
    Sep 2015
    Dallas Texas
    53
    I bought some generic "regular scent" bleach at the grocery store. When I used it, it literally had no scent. I'm concerned it's expired or too diluted; does unscented/regular scent not smell like the traditional bleach odor?
    Fiberglass pool 5300 gallons (trilogy eclipse)
    inground
    Cartridge filter
    2HP hayward ecostar sp3400vsp
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Unscented/regular scent bleach
    Bleach itself doesn't have much scent, until it starts to oxidize something. Pour a little into the sink, then take a whiff.
    Alternatively most bleach bottles have a "born on" or expiration date code on the bottle. Many times it looks like this: "16058" or something similar. 16058 would mean it was made on the 58th day of 2016. See this thread here: Chlorine Date Code Decoder/Easy Way to Measure Strength.
    The older bleach is, the more strength it has lost.
    Isolated Spa - 345 Gallons
    Sep 2015
    Dallas Texas
    53
    Quote Originally Posted by Meaty View Post
    Thanks; makes me feel better. I'll try to determine its age too. How long does bleach typically retain its potency?
    inground
    Cartridge filter
    Feb 2014
    Central Minnesota
    5,080
    That's a complicated answer. The higher the initial concentration, the faster the hypochlorite will decay. Higher temperature will increase the rate of decay. Exposure to UV light will cause decay. Metal contaminants not removed from the bleach during manufacturing will increase decay.
    When stored properly, regular old grocery store bleach that is fresh when purchased should retain most of it's strength for 2-4 months before noticing a loss of strength.
    Feb 2016
    Austin, TX
    13
    Did the generic bleach show the percentage concentration of acid? The generic bleach that was left by the contractor didn't list the concentration (about 15 bottles). It hardly had any smell and i'm real sensitive to the smell of bleach. Though it was about 6 months old.
    I'm using 10% pool chlorinating "bleach" by Pool Essentials from Walmart for $3.64 a gallon, 10% sodium hypochlorite concentration. Probably about the same price that I can get the 3 packs of Clorox bleach from Sam's Club or Costso, which are a bit smaller (121 oz) and have a lower concentration (8.3%). Think i will use this to clean the cedar fence too.
    Austin, TX
    17,000 gallon pool
    In ground.
    Concrete.
    Crystal Water DE Filter - 48 sq ft.
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    One way to determine if the bleach is still "good" is to test your FC about an hour after adding it and see if it brought your FC to the desired level (per PoolMath)
    Sep 2015
    Dallas Texas
    53
    Quote Originally Posted by Alloy25 View Post
    Unfortunately not, it doesn't list the concentration. I'll have to pay better attention when I buy next
    Quote Originally Posted by YippeeSkippy View Post
    Great idea. Thank you
    inground
    Cartridge filter
