Thread: Intex Pump Low Flow
    May 2014
    san tan, az
    61
    Intex Pump Low Flow
    Hey there TFP,
    I am trying to figure out what is going on with my pump/filter. I opened the pool last week and went to attach my Kreepy Krawley and nothing happened. I have backflushed/rinsed multiple times. I have the 2150gph model (3rd season). Here is what I am seeing:
    Backflush/Waste gives very strong flow on the return. Kreepy gets moving
    Recirculation gives very strong flow on the return. Kreepy gets moving
    Switch to filter and flow is cut by at least 50%. Kreepy stops moving
    PSI remains around 10 with all these settings (right on the edge of green to yellow)
    I am using recirculate right now to get the chlorine moving, sweeping, etc.
    I have taken the pump apart, checked all hoses, removed the SWG to reduce possible causes, took cap off of filter and cleaned the plastic screen that is attached. Sand level is still 2/3rds full.
    Any ideas on what could be happening or something I am missing?
    Thanks!!
    18'x48" Intex Ultra-Frame (Grey), Intex 2150gph Sand Filter (#28647EG), Intex Krystal Clear SWCG (#54601EG), Hayward SP1091LX Dyna-Skim, Intex LED Light.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Intex Pump Low Flow
    When was the last time you deep cleaned your filter? See this thread on a bit of how to.
    May 2014
    san tan, az
    61
    Thanks for the link! Haver never done that and will try it tomorrow.
