Results 1 to 8 of 8
Thread: Radiant Metric 24' Round IG DIY Install - Am I Crazy?
    Mar 2016
    Greenfield, Indiana
    3
    My wife and I have been discussing installing a pool for years now. I have been going back and forth on whether I should do it myself or hire it done. I am pretty handy with basic construction, plumbing, and electrical. The one thing I'm a little worried about is the excavation. We are planning to install Radiant Metric 24' round pool with concrete deck, so the the hole should be pretty straight forward (28ft diameter, 4ft deep, flat bottom). After install, I will have someone come in and poor the concrete deck. A local PB quoted me at $6400 for just the pool kit (not sure if that includes pump, filter, etc.). Am I crazy for wanting to attempt this myself? By the way, I'm a teacher, so I'm off for 2 months in the summer.
    Experience
    Construction: 2 wood privacy fences, 2 - 10 x 10 wood storage sheds (from kits), 2 decks, 1 wood playset (from kit)
    Plumbing: Multiple bathroom and kitchen remodels, plumbing repair/replacement 400GL Hot tub
    Electrical: wired new lighting fixtures/switches, installed/wired 220V Hot tub, replaced computer control box in hot tub.
    Excavation: I ran a SEE (Small Emplacement Excavator) Truck in the Army a few times many years back, but I was digging trash pits that didn't have to be very accurate.
    30,427
    Re: Radiant Metric 24' Round IG DIY Install - Am I Crazy?
    Welcome to the forum. I see no reason why you can't DIY your pool. Hundreds of us on the forum have already done so and we are all happy to help each step of the way
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,572
    I say go for it and share LOTS of pictures and ask LOTS of questions. Someone will jump in to help I am sure!
    Kim
    Mar 2016
    Greenfield, Indiana
    3
    In your experience, am I really going to save enough money to make it worth the time and effort?
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    You'd have to see what the install charge is. I don't think so personally. You can certainly do it but enjoy your vacation. You'll be working harder at home than at work. Treat yourself!
    You need to consider that you'll need to rent a laser level, mechanical tamper, and possibly a sod cutter at the least. Is the ground flat? Seeing my first pool go in (27' ag) I was glad I spent the money to have it done. They will have it done a day (unless you have a steep slope which I did but then it was only 1.5 days).
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    May 2013
    Albany, NY
    59
    PM sent. Post lots of pics, and reach out to me with any specific questions!!
    Eric Adams, Technical Specialist, Radiant Pools
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    pay for the excavation, and pay for the concrete. Do the rest yourself. Check out their website, they have a .pdf of the instructions, read though them and you will see how easy it will be.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    Mar 2016
    Greenfield, Indiana
    3
    Quote Originally Posted by Nectarologist View Post
    This will likely be an inground or semi-inground install.
