Results 1 to 18 of 18
Thread: Not as exciting as pool build or remodel, but...
    Dec 2015
    Silver Spring, Maryland
    30
    I realize building your own pool is far 'sexier' than replacing equipment, but I thought I'd document my journey as a newbie.
    Background: Purchased house beginning of October, closed pool 3 weeks later, fired previous owner's pool guy shortly after getting a $600 bill for closing. I began snooping in December - after 4 months, many hours of research, several estimates, a few posts on this forum, and one large credit card bill - everything is finally going in tomorrow!
    As you can see, most of the existing equipment is pretty old. It all worked OK, but we figured it was time for an update.
    (PS I apologize for the blurry pictures, the autofocus on my iPhone is broken!)
    We're getting a Pentair intelliflo VS, Easytouch 8SC w/ Intellichlor IC60, Rheem 406 (cupronickel), as well as some other items such as changes to the plumbing and a new electrical "rack".
    A fencing company is replacing the awful fence the day after.
    This is similar to what is going to be put up
    Tired of looking at this too! Bring on the warm weather!
    ~24k gallon 38x22 figure-8 freeform pool w/ spa. Pentair EasyTouch 8SC w/ ScreenLogic2, intelliflo VS 011018 3HP, Intellichlor IC60, FNS Plus 60 DE filter w/ multiport valve, Raypak R406A cupronickel (360k BTU). ColorSplash 2G LED, Dolphin Nautilus Plus, Polaris 280 with 3/4HP booster pump.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    Re: Not as exciting as pool build or remodel, but...
    I love that fence! Looks amazing!!!!! Can't wait to see photos.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,442
    JD,
    I think you will be very happy with your choice of equipment. Make sure to take some pics of the finished product to share with us..
    Suggest you make sure they install your new pump with unions so that it can be easily removed, if necessary. The pump does not come with unions, so unless you ask they will just glue it right in place. What size input service (amps) do they plan to run to your new EasyTouch? The bigger the better as you never know what you might want to plug in at some future date.
    Oh!! You will love the ScreenLogic system.
    Dec 2015
    30
    I'm not sure how many amps are going into the EasyTouch, but the breaker out there gets 30 amps currently. I also didn't know about adding unions, I will have to ask about that when they come tomorrow.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,379
    Add a by pass on the heater as well for the times you will need to by pass it.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Good stuff! Thanks for sharing.
    Dec 2015
    30
    They came today, unfortunately they weren't able to finish everything in one day. They'll be back on Thursday to redo the electrical stand, add the EasyTouch system, and open the pool. I took a few pictures of the progress so far.
    Maybe someone with plumbing experience can chime in? I'm not sure how well of a job they did or didn't do.
    By the way-I did not realize how BIG this heater would be, it's at least 50% larger than the old one.
    And here is the old heater, about to get trashed. Totally rusted out on the bottom!
    Feb 2016
    Houston
    323
    Ooo that new fence is going to look nice!
    Dec 2015
    30
    Finally almost done. The pool company took several days longer than originally expected- apparently they used this as a training 'refresher' course since I was the first person this season to have an installation.
    In retrospect, I wish I had them rearrange the equipment pad. I got lucky that the fence company was able to coordinate with the pool guy, because they had to add a gate where the EasyTouch was installed. Also, I was unable to be present the second day and was surprised to see them building a fence that looked different-and was taller-than what I wanted. I'm actually really glad it's taller!! But some of the other details I had wanted were missing.
    I hope staining it in a few weeks will change the look even more. I'm really bummed it didn't turn out like the picture I previously posted, but I don't dislike it.
    Don't mind the mess- it's a little too cold to start spring cleanup. I have a LOT planned...
    All the equipment is pretty much good to go.
    I mounted an iPad to the wall in the kitchen and wired it in. Works with Screenlogic, Nest, Sonos, and I can watch TV on it using my Dish Anywhere app. Pretty cool!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    that is a nice setup
    Nectarologist's Avatar
    Apr 2015
    New York
    426
    Looks great (ipad and equipment/fence).
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Sleek and snazzy!
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Jan 2016
    Mesa, Az
    541
    Can you post a lnk to that iPad frame? That's a sweet looking set-up.
    Jun 2013
    Augusta, GA
    90
    Nice setup! I wanted to add a comment about your plumbing, since you asked for it. I do not see unions anywhere n your plumbing. How are you to remove equipment without cutting the pipes? Perhaps I am missing something.
    30'x52'' AGP 21,000 Gallons
    TWM 2.64 SF Sand Filter w/ Century 1.5 HP Pump
    BBB'er for life!
    TF-100 Test Kit
    Jul 2012
    Tallahassee, FL
    30,379
    Pretty cool?????? Nope! It is VERY cool! I love it!
    Now get some roofing felt and put it down under and around the equipment with river rock or such on top of it to make it pretty and keep weeds out. Maybe some pavers for barefoot walking.
    I can't wait to see what else you do. If it half as good as what you have already done........it is going to be GREAT!
    Kim
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,797
    Quote Originally Posted by tommyd123 View Post
    I do see them on the salt cell, the thing on the left and the heater, just not the Neverlube. They are black and gray and sort of blend in with the equipment they are attached to.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    576
    The way you did the pool equipment fence, gives me something to think about lol
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Dec 2015
    30
    Thanks for all of your comments! It won't look so drab once all of the leaves grow back.
    Here's the link to the iPad frame. It is very high quality, sturdy, and wasn't toooooo bad to set up. I plan on buying another one for the master bedroom too. I should have gotten a black iPad for it instead of white, it would have looked better with the silver frame.
    http://www.vidabox.com/kiosks/vidamount-ipad-metal-wall-frame-mount.html
    Quote Originally Posted by kimkats View Post
    Kim
    Thanks! I actually ordered some super-bright white pebbles that I plan on putting there.
    The previous owner did a weird thing with the patio 3 years ago. They did a really nice (and HUGE) concrete slab between the pool and the house, but they put those weird stones you see in the photo in 2 areas. They're actually not too bad to walk on, but they're not visually appealing nor totally level. Those stones only take up about 200sq ft of over 1,500 sq ft of patio space, so it's not too big of a deal to me at this point. I do plan on replacing it, but probably not this year.
    The yard needs a lot of landscaping. I love that it's completely flat and open, but I want the pool area to feel more intimate and resort-like. I'd like to do that without significantly increasing the number of leaves that fall into the pool.
    If you guys like that, you should see what I did to the INSIDE of the house
