Thread: Should Used Solar Panels (Fafco) Be Flipped Upon Reinstallation?
    Nov 2015
    Cape Coral, FL
    9
    I bought some used Fafco Solar Panels off of Craigslist. You can tell which side was up due to the strap marks and difference in color from the sun vs the bottom side.
    Just wondering when I install should I keep the same side up or flip them so the newer looking side is up?
    Thanks!
    15,282 Gallon, Pentair Intelliflo 3HP, Pentair CC150 Filter, Pentair 320 Chlorinator.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Should Used Solar Panels (Fafco) Be Flipped Upon Reinstallation?
    Flipping them sounds like a good idea to me given UV exposure is probably the biggest enemy of panels.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Yeah, I agree with that logic. Maybe I'll go flip mine in a few more years.
    Apr 2015
    Brookline
    60
    Bringing up a old thread, however i am thinking about doing this. It's been three years on one side, might be time to flip. I cant see how it would hurt
    Southern New Hampshire, 18x36 single roman end pool.
    38,524
    I have Helicols and flipping them would be a ridiculous amount of work because each tube is individually snapped into 3 or 4 cross members. I bet I would cause more damage trying to pull them all out and snap them back in than just leaving them alone.
    I did fire it up again this year and my 10 used panels have for the 3rd year I have had them had 0 leaks
