Thread: Minimax NT heater hi limit
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    I had run out of propane so I hadn't used my tub for awhile. Tub worked great before that. Went to fire up and there was no power at all to heater. Had a tech come out and tell me it was the transformer. Ordered one and put it in. Got power and now the hi limit light comes on. It was working fine before and now this. I read up about some new parts to consider. What's happening? All of a sudden everything is needing replacing? I'm just asking what to check next. The hi limit is on and the water is cold. Cleaned out filter and can feel and hear water running through heater and also have good flow at hot tub. Any thoughts would help greatly. Thanks.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Minimax NT heater hi limit
    Seems odd that he didn't address this new error while he was there.
    Essential Links:
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    There was no power at all when he was out. Said transformer bad. It cost me 30.00 to replace myself compared to 132.00 from him. I replaced and then I received Hi temp reading, though no E02 message, just Hi.
