Thread: Stegmeier Channel Drains - Replacing old channels - Best Options Please
    Jun 2014
    Fresno CA
    9
    Cool Stegmeier Channel Drains - Replacing old channels - Best Options Please
    My Stegmeier channel drains are 29 years old, have become brittle, cap less in many areas and generally worn out. How do I go about replacing these drains. I have heard a circular saw with cement cutting blade is used to remove the old drain. Is this correct? Is there a replacement available?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Stegmeier Channel Drains - Replacing old channels - Best Options Please
    Can't you just replace the cap.
    stegmeier
    chiefwej
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,579
    Share a picture so we can see what you are dealing with. We might have some more ideas.
    Kim
    Jun 2014
    Fresno CA
    9
    kimkats and others: Here are two photos I had in my photo library. I can add others within a day or two (heavy rain at the moment).
    Jun 2014
    Fresno CA
    9
    Chiefwej,
    As you can see in the earlier reply to kimkats (with photos), there is nothing left for which to attach the cap.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If you read their website it's says the cap is put in with adhesive. Click on the link I gave you. I believe you just clear out the channel and apply a small bead of adhesive along each side of the opening, then push in the cap. You just need to be sure that it's the right width, this is for their 2 inch wide Super Drain not the 1.6 inch standard deck drain. You can contact them for more details.
    chiefwej
