Thread: Chlorine-Free Sun Shock Pool Purifier
    Apr 2015
    Katy, TX
    65
    Hello,
    Has the anyone use this device before? Here is the device at Costco:
    It says this device reduces the need for chlorine by 80%. Any comments would be appreciated.
    Brian
    24K gallon, IG, plaster, Pentair Clean and Clear Plus Filter, Pentair Heater, Pentair Intelliflo pump, Built in March 2015, Taylor K-2006, Spa included
    Donldson's Avatar
    NW Ohio
    2,903
    Re: Chlorine-Free Sun Shock Pool Purifier
    Copper ionizer powered by a cheap solar panel. The low output of the solar panel will make it a pretty underwhelming ionizer, and the fact that it is a copper ionizer gives it my stamp of disapproval. If it does manage to put enough copper in your pool to make a difference then you will risk staining the plaster.
    Also, the name is really misleading. It implies that this is some sort of chlorine-free sanitizer, which is most certainly is not. It is just another overpriced algae-prevention device that introduces potentially stain causing minerals in to your pool.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    JoyfulNoise's Avatar
    May 2015
    13,226
    Yeah, what Donldson said....
    This falls under the category of calcium reducing pipe magnets, solar "enhanced" power crystals, rainbow powered unicorn flatulence and The Publisher's Clearing House Sweepstakes.....and I think I'd have better luck with winning the sweepstakes....
    All kidding aside, Cu does kill algae (and that's about it) but it comes at a cost of larding up your water with metal ions and potentially staining your plaster (most people try desperately to keep metals out of their water). The tiny incremental benefit of adding Cu to your water is completely offset by the HUGE cost of trying to rectify stained plaster. Plus, if you really want Cu ions in your water, it's way cheaper and easier to just throw a few ounces of cupric sulfate algaecide into your pool and not have to deal with the spaceship-like pod floating around in your water.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
