Thread: Clean Mode iAqualink
    Oct 2015
    humble texas
    132
    Guys-
    My inline chlorinator only runs during "CLEAN MODE". Im just curious what I should be setting clean mode for anyhow. Right now I CLEAN MODE sent to M-F 8am- 2PM. Does this seem right?
    Oct 2015
    humble texas
    132
    Re: Clean Mode iAqualink
    Guys any help here giving a BUMP Thanks in advance!
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Can you update your signature with your equipment so we can see what we're dealing with?
    I don't believe many of us use an inline chlorinator and I'd have to look but I don't think mine has power. It's just an inline repository. So it gets flow whenever the pump is running.
    Forgot - how long your cleaning cycle runs depends on how much debris you get in your pool and how much you use it. I think I read on here that most residential pools only need 3 or 4 hours of circulation for cleaning.
    I run my In Floor system and variable speed pump on high for about 4 hours per day and let the variable speed pump run another 4 hours on low.
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    It sounds like maybe you have an SWG? +1 to adding your pool info to your sig so we can help. Here is how, Pool School - Read This Before You Post
    Oct 2015
    humble texas
    132
    Here is the signature
