Thread: Intermatic PE1353ME Wiring Question
    Hi All! Dad and I are debating the the wiring diagram. I have chosen to use Mode 3. Each of the circuits has there own dedicated outlet. I will have a pump on circuit 1, Aqualuminator light on circuit 2, and Stenner on circuit 3.
    Now for the debate: Does it go from the circuit breaker to load and then from line to the outlet? Or does it go from the circuit breaker to line and then load to the outlet?
    My pool: Sharkline Venture 24' x 52" ; Pentair Dynamo 1 HP 2 Speed Pump ; Pentair SD80 Sand Filter; TF-100 Test Kit w/ Speed Stir
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,488
    Re: Intermatic PE1353ME Wiring Question
    Callie,
    The power should go from the CB to the "Line" input to the relay, then through the relay contact and then to the load.. Although I'm not too much of a fan for only shutting off only one side of a 240 volt circuit. It is better, whenever possible, to shut off both 120 volts sides of a 240 Volt circuit.
    Jim R,
