Thread: solar panel glue
    solar panel glue
    I have some suntrek solar panels/tubing that came detached from our southwestern style tile roof after a wind storm. the system is 10 years old and all the tubing components are glued to the roof tiles. I am not the original owner so no warranty is applicable to me. I just want to get on the roof to reglue the tubing where it was originally attached. whats the type of mastic/adhesive do I need to use to bond the tubing (synthetic rubber?) to the concrete roof tiles?
    35,000 gal pool
    Pentair whisper flo & Cartridge Filter
    Caretaker 99 in floor
    Suntrek Solar panels
    Las Vegas,NV
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: solar panel glue
    You will likely want to use a roofing mastic to reattach it, this is often gooey thick sticky stuff that dispenses with a caulking gun, I used a product by Chemlink called Duralink when I installed my solar panels, however I was installing on a metal roof. In fact I still have 4 or 5 tubes left (bought a 12 pack online, probably broken even vs buying by the tube)
