Thread: Filter Tube
    Sep 2011
    Omaha, NE
    95
    Filter Tube
    Bought a new sand filter and attached to the lateral end is a small clear tube with small filter on end. Does anyone know where this is supposed to go. Does it get buried into the rest of the sand or stay above the sand level. Direction do not even mention it.
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    Jun 2014
    15,212
    Re: Filter Tube
    That looks like it may be an air relief tube. Sometimes they are connected to a spot on a multiport vale, others just left above the sand. Here is a quote from one company that addresses such a tube:
    Clear plastic tube attached to standpipe is an air relief. As you are adding the sand into the tank, try to hold the tube up against the standpipe. The white piece on the end of this tube should be ABOVE sand level when you are done adding sand to the filter.
    Sep 2011
    Omaha, NE
    95
    Re: Filter Tube
    Great, thanks for the info. What manufacturer did you find that for? just curious? I thought it might connect into muti-port valve also, but do not see anyplace for such a connection..
    16X24 Oval Doughboy
    10,000 Gallons~
    Re: Filter Tube
    It's an internal air relief. You want it inside the filter as high as possible.
    Support the site
    Jun 2014
    15,212
    Re: Filter Tube
    fritz, I couldn't find where I copied that original reply from that I quoted earlier, but here are a couple others:
    Technical question about sand filter
    http://www.google.com/url?sa=t&rct=j...F-63f3amVC3QBw
    Sep 2011
    Omaha, NE
    95
    Re: Filter Tube
    Thanks, helped alot!
    16X24 Oval Doughboy
    10,000 Gallons~
