Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: Cleaning Stained Steps
    Jun 2014
    pensacola,fl
    104
    Ok so I figured I would start a new thread instead of asking this question in the SWG thread I have going. My steps got horrible due to me not keeping up with the pool over the winter for multiple reasons. I tried using a magic eraser and that didn't help. Any suggestions on how to clean these steps? I would like to get them white again like they were last year. Thanks you for any considerations.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    18x36 ft in ground vinyl liner pool Approximately 27000 gal. Pump is Pentair IntelliFlo variable speed pump with Hayward sand filter and Hayward Aquarite Salt System with T-15 Cell. K-2006 Test Kit
    Aug 2014
    Northern IL
    4,615
    Re: Cleaning Stained Steps
    Put a couple of vitamin C tablets in a sock and scrub the stairs in a small area. See what happens and let us know. If it works, wait for instructions before cleaning the stairs completely.
    Jun 2014
    pensacola,fl
    104
    Ok. I'll try it in just a few minutes.
    Jun 2014
    pensacola,fl
    104
    Ok so I did it and it seems to be definitely making it lighter. It didn't take it off completely but I only scrubbed for about 3-5 mins.
    JoyfulNoise's Avatar
    May 2015
    13,251
    They are likely iron stains. You will need to do an Ascorbic acid treatment -
    Ascorbic Treatment to rid Pool of metal stains
    Follow the procedure exactly. Many people often just do the AA treatment which gets rid of the stains but then neglect to add a proper metal sequestrant. Once the chlorine is brought back up, the stains return. You have to follow the procedure exactly in order for it to work.
    Matt
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,626
    Please take LOTS of pictures starting with one where you did the first rub with the vit. C. That way it can help others.
    Kim
    Aug 2014
    Northern IL
    4,615
    If the staining on your steps is iron (and it sounds like it as vitamin C -ascorbic acid- helped), there is likely staining on the vinyl walls too. I am sorry. I know you just finished a slam...
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If you just think that vitamin C helped, you need to be very sure before proceeding. Find the darkest stained horizontal surface and put a few vitamin C tablets right on it. The next day you should have a clean white area if it's working. There should be no doubt if it is in fact metal staining.
    There are other sources for stains like that and the treatment differs.
    chiefwej
    Aug 2014
    Northern IL
    4,615
    Show us another pic post-vitamin C, please.
    Jun 2014
    pensacola,fl
    104
    I just got this but I only did a small spot about the size of a half dollar. It's to dark for me to take a picture now. Honestly if I have to get the chlorine to 0 I'm going to have to wait because I just got done doing a slam and getting pool cleared up. I'm not taking the chance of getting algae back right now. Lol.
    Jun 2014
    pensacola,fl
    104
    Quote Originally Posted by kimkats View Post
    Kim
    I will take some pictures tomorrow and tonight I'll put one of the vitamin c tablets on the darkest spot and we will see if it makes it white.
    Jun 2014
    pensacola,fl
    104
    [IMG][/IMG]
    Ok so I was able to take some pictures. Thought it was too dark but they turned out ok. Its not the darkest spots because they are on the sides. I put 3 tablets on them and we shall see what they look like in the morning..
    [IMG][/IMG]
    Aug 2014
    Northern IL
    4,615
    Well, if you spent 3-5 minutes scrubbing a half-dollar spot to notice a difference, that sounds like something besides iron.
    Jul 2012
    Tallahassee, FL
    30,626
    Here is hoping!
    Kim
    Jun 2014
    pensacola,fl
    104
    Quote Originally Posted by MarianParoo View Post
    Hopefully its something else... My pool was pretty nasty... I can't believe I let it go but we had a lot going on so... We shall see if it takes the stain up in the morning........
    Jun 2014
    pensacola,fl
    104
    Well I just checked where I put the tablets. Its white...
    [IMG][/IMG]
    May 2015
    13,251
    That's good news. It means an AA treatment will work. Believe me it's way more frustrating to have brown stains that don't respond to either vitamin C or chlorine.
    Matt
    Aug 2014
    Northern IL
    4,615
    I know you prefer not to do an AA treatment now. I get that. For a temporary improvement, you could scrub the stairs with the sock method, but do it when your FC is on the low end of your range as chlorine makes the Vitamin C less effective. Just an idea.
    Jun 2014
    pensacola,fl
    104
    Yeah but that would be a lot of scrubbing.. Lol I wonder where a good place would be to get AA cheaper around here. My FC is down to 6 so I might as well go ahead and let it come down and do the treatment. I want the pool to be open by next month. I just don't want to get algae back and have to start the slam all over again. But I guess I don't have much of choice.
  20. Back To Top    #20
    May 2015
    13,251
    Try Amazon or The Chemistry Store. You shouldn't need more than a few pounds.
    Matt
