Thread: Water cloudy
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Water cloudy
    Hey guys!
    Ok, pool is all vaccumed out, filter's been running 24/7 for almost a week now and water is still on the slightly cloudy side.
    CYA is at 40ish (prefer 50)
    ph 7.5
    TA 110
    CL- not sure, it was dark yellow,(just did the quickie test and not the full out one) and I added 172 oz bleach tonite.
    Should I continue to vaccum- even though all debris is out of the pool(there was A LOT pinestraw,pollen)
    So I am assuming add more bleach and keep it at shock level about 16 for a few days??? and until my CC read .5 or less? I hope I don't have to add any clarifier.
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    30,297
    Re: Water cloudy
    Hi, Laura,
    Have you backwashed? Did you get a pressure drop? what is your current pressure?
    It sounds like your filter is a little small for your pool but, yes, keep your FC up until your water is sparkling. A week is a little long for it not to clear. Tell us some more about your filter and pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,965
    Re: Water cloudy
    Have you done an overnight test? Is your FC holding.... I agree with Dave - some more info on your pump. There's an article in pool school/further reading about adding DE to your sand to help with filtration...you could try that if nothing else seems to work.
    http://www.PerfectlyClearPoolService.com
