Results 1 to 7 of 7
Thread: Do I need a Salt water test kit?
    Feb 2016
    McKinney. TX
    42
    Just converted to salt from a chlorine feeder. Can I still use my "fresh water" test kit for things like Cl, TA pH etc? I have some strips that allegedly tell me my salt saturation, but will take a sample to the pool store for more detailed info on that.
    12,000 gallon, in-ground, Lunar Quartz-Bermuda finish. Pentair Intelliflo Pump and Pentair cartridge filer. Polaris 280 pool sweep. Circupool SJ40 SWG.
    Aug 2014
    Northern IL
    4,615
    Re: Do I need a Salt water test kit?
    What kit are you using?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    It is good to know your approximate salt level. But, the most important thing is that your SWG is happy with the salt level and producing chlorine.
    Here is the water chemistry for a saltwater pool, Pool School - Water Balance for SWGs
    Yes, tests for FC, PH, CYA, TA and CH are all the same for fresh water or saltwater. Do you have a good test kit? I use the TF100 from TFTestkits.net
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,387
    Your pool will be cleared and cheaper if you get your own test kit. You do need one even with salt. The TF-100 is the best bang for the buck.
    Kim
    Feb 2016
    McKinney. TX
    42
    Yup, I have the TF100 as well. Thanks.
    Aug 2014
    Northern IL
    4,615
    Then yes, that is the perfect kit to continue using for all the routine tests! Some people get a salt kit, some just use strips.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    I have the Taylor K1766 salt test kit. I got it mostly out of curiosity rather than need.
    Like pooldv says, the important thing is that your SWG is happy, and don't have any alarms.
    The point is that with salt, it doesn't matter what the test result is, as long as its working all is well.
    The strips are more accurate when they're fresh, but still not very reliable by themselves. Even the K1766 is accurate to only a couple or 3 hundred ppm.
    What I do, and works well for me, is do nothing unless the low salt alam light comes on, then add a couple of bags at a time until the low salt alarm goes away. Then add another couple of bags for good measure and I'm good. Of course this only works because I check my SWG staus at least every couple of days, which is good practice for everyone.
    Divin Dave,
