Thread: Circupool SJ40
    Feb 2016
    McKinney. TX
    42
    Circupool SJ40
    Just converted to saltwater. Anyone have a Circupool SJ40? Installation went smoothly. Noticed on startup that the center plate (5 plates in the cell) vibrates slightly over the inlet side of the cell. It is situated over the "up tube" where the water enters the cell. Contacted manufacturer, still awaiting their response. Guess it might not matter as the cell have a 7 year pro-rated warranty. Just wondering if anyone else has noticed this.
    12,000 gallon, in-ground, Lunar Quartz-Bermuda finish. Pentair Intelliflo Pump and Pentair cartridge filer. Polaris 280 pool sweep. Circupool SJ40 SWG.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Circupool SJ40
    I have one also, it does look like it moves just slightly.. I ran mine for 4 months last year and nothing happened, it seemed to move less as time went by and I just opened and did not see it moving at all this year...
    Feb 2016
    McKinney. TX
    42
    Re: Circupool SJ40
    Quote Originally Posted by cowboycasey View Post
    Great. Thanks. Still awaiting an answer for Circupool, but that might take a while.
    Feb 2016
    McKinney. TX
    42
    Re: Circupool SJ40
    Talked with the manufacturer today and they informed that the slight vibration is designed to help keep the plates cleaner. It's perfectly normal.
    Mar 2016
    Fort Mill/SC
    41
    Re: Circupool SJ40
    not to highjack this thread, but how do you like the SJ40, thinking of getting this rather than the Pentair IC40 for a self installation
    2010 In Ground ~ 12-15,000 Gallon estimated
    ~3 ft shallow ~ 6 ft deep ~38 ft x 17 ft Freeform shape Pebbletec Finish
    2 Drains, 2 Skimmers, Sidewall Vacuum (Not in Use)
    Dolphin Oasis Z5 - PHPF1.0 Pump - Jandy CV340 Filter
    Fort Mill, SC
    Jul 2013
    Fletcher, OK
    3,353
    Re: Circupool SJ40
    I love mine, it is a simple SWG meaning it has no screens, voltages, watts, it just has an on and off button and 25%, 50%, 75%, and 100% setting on it... It has been humming along on its second year so far
