Thread: Heat Pump thoughts for PHX inground
    VA2AZ's Avatar
    Mar 2013
    Avondale AZ
    22
    Cool Heat Pump thoughts for PHX inground
    Last Nov, I had my 4' to 7' deep, 12'x24' plaster pool renovated to a 3.8' deep x 12'x24' pebblesheen pool. Approx gals went from 12.2k to 8.4k. right now pool is coming alive with winter temp of 49 leaving for 67 and rising every day. Running Nat Gas to equipment area is cost prohibitive, so I decided to go with a heat pump; just haven't figured out the BTU size yet.
    Here is my goal: Typically I started getting in the pool on 1 May (82F) and closed it mid October (82F). I would like to go to at least until 1 DEC and reopen on 1 APR. Does anyone in the PHX area have experience with a heat pump? Any thoughts would be appreciated.
    IG 8.4k gal, 12x24, pebble sheen, SGS3000 SWG, Triton II TR100HD sand filter, PCC2000 pop up clean, 1hp 2EZ Speed motor with Whisperflo pump for filter, 1hp Century Sq1102 motor w/whisperflo pump for clean, 3.8' pool depth, 2002 build date - Nov 2015 refurb date. Went from 12.2k gal to 8.4k gal and from plaster to pebble sheen w/abalone shell.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,460
    Re: Heat Pump thoughts for PHX inground
    The Hayward HP50HA is probably a good option for your climate and pool size.
    Here is where I got mine,Hayward Heat Pump HP50HA | Hayward HP50HA
