Results 1 to 18 of 18
Thread: Opened too late, pool slightly green...
    Jun 2013
    Newcastle, Oklahoma
    508
    Water is still at 55 degrees, chemical numbers:
    FC - 3
    CC - 0
    pH - 7.2-7.3... its kinda in the middle... tested it twice.
    CYA - ~25ish... hard to tell as the tube maxes out a 30...
    Obviously I need to slam, the wife is grabbing me 8 bottles of bleach as I type this... Ill slam it til it goes clear.
    I cant remember though... thinking I need to wait to adjust CYA until after SLAM is complete, right?
    I know with a lower CYA it will take less bleach to slam... 15 ppm by the trusty pool calc...
    and what about pH? 7.2-7.3 isnt horrid, im thinking slam first adjust ph afterwards, however, I just pulled cover off an got pump going today, I have noticed that its normal for my pH to be low at first and after a week of no cover and pump running it goes up to where it is supposed to be.
    thoughts?
    thanks!
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    JoyfulNoise's Avatar
    May 2015
    13,213
    Re: Opened too late, pool slightly green...
    Yes, DO NOT adjust CYA. Just SLAM it. Your pH is fine for SLAM.
    Matt
    Jun 2013
    Newcastle, Oklahoma
    508
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    Thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    +1! Yep, you're right on track. Here are the details if you want to review. Pool School - SLAM - Shock Level And Maintain
    30,421
    Just to clarify, the CYA test in that kit STARTS @ 30 and maxes out at 100. So you are saying you are filling up past the 30 mark and the black dot is finally obscured?
    Jun 2013
    Newcastle, Oklahoma
    508
    yes. it is obscured just slighty above the 30 mark.
    how long does it usually take to get from aqua marine green to crystal clear? a few days?
    Jun 2014
    15,152
    Each pool and scenario is different. You can expect it to take a few days to pass all 3 SLAM criteria. Keep the bleach handy and maintain. You can do it!
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by Texas Splash View Post
    yeah, thats what I was thinking. I bought enough for 3-4 days.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    It is done when it is done...............there is really no way to tell. You can do it faster by making sure the FC NEVER drops below SLAM level for your CYA.
    Don't forget to brush at least once a day. Try for 2 if you can.
    Good luck! Keep taking and sharing pictures looking down at our steps. That is the best thing for us to see the progress.
    Kim
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by kimkats View Post
    Kim
    here is what we are starting with. I over shot somehow the FC amount needed. Pool cal says 13 ppm for cya of 30, I poured in 3 121oz jugs of 8%, tested an hour later at opposite end of the pool, got 18ppm, oh well, better a bit too high than too low. ill test again in the a.m. before I head out to church and again soon as I return after noon.
    Aug 2014
    Northern IL
    4,615
    Try to test in the same place every time; along side at mid-depth and not too close to a return. You go!!!
    Last edited by MarianParoo; 03-05-2016 at 11:34 PM. Reason: Lots of fat thumbs on my phone...
    Jul 2012
    Tallahassee, FL
    30,525
    We will get you clear easy! Good job on the start.
    Keep that pump running and FC up and you will fine!
    Kim
    Jun 2013
    Newcastle, Oklahoma
    508
    update: seems to be clearing nicely. i have had to backwash twice as my filter would get so full, nothing was coming out of returns. ugly nasty brown backwash water. I run my dolphin nautilus every 6 hours to keep the dead algea cleaned up of the bottom and im brushing the sides twice a day. Ive been keeping the FC around 19-20 even though calc says 13, i want to make sure it never drops below shock level. so far the lowest it has went was 17. pump has been on constant HI since 6 yesterday when I started the slam.
    Jun 2014
    15,152
    You're doing good on the FC "maintain" part. Stay with it. This will all be behind you before you know it. Patience is key.
    Aug 2014
    Northern IL
    4,615
    It's already starting to look better! Good job!
    Jul 2012
    Tallahassee, FL
    30,525
    Glad to hear it is working for you! You are doing everything right!
    Kim
    Jun 2013
    Newcastle, Oklahoma
    508
    We have went from green to pretty blue with a pretty clear bottom!
    she still isnt crystal clear though... so slamming continuing.... FC still holding at 19ppm... a bit on the high side....and thats right where ill keep it.
    next stop.... crystal clear, which I expect to see tomorrow...
    Once it hits crystal clear, ill hold slam level for 2 more days to make sure before I do OFCL test and CC testing, just to make sure every single cell of algea is dead, water is still below 60 degrees, so not like I can swim... so might as well hold high levels for a couple extra days as extra insurance that im done.
    Aug 2014
    Northern IL
    4,615
    That's what I would do. Good job!
