Thread: Too much water in a new pool
    Mar 2016
    Corona, CA
    1
    This is my first post. We were supposed to fill our pool to halfway of the tile line, which we did, and then fill the spa. We were told the spa would take 12 hours to fill, but it only took less than 2 hours and then was spilling into the pool. We bucketed out about an inch this morning, but is it okay to leave now? When I caught it, there was about an inch of tile still exposed. Thanks!
    Elissa
    NEW pool install, bean shape
    Salt
    Pentair - unknown
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    Re: Too much water in a new pool
    You want your waterline about halfway up the face of the skimmers for the best skimming action. Welcome!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP,
    There shouldn't be any issue with the level where it is. Just let it level off to where it's spilling into the pool when circulating, and no worries. As for the pool level, Woody has it covered. We were answering at the same time Woody, sorry..
    Essential Links:
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Welcome Elissa.....can you backwash to drain some down if needed to? Water level needs to be midway up your skimmer. If it's to high your skimmer will not be able to skim properly.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Sabercatpuck's Avatar
    Feb 2016
    Deltona, FL
    122
    If your pump and piping system allows for a drain to waste you can let the pump drain it down for you. It would probably only take a few minutes so watch closely.
    28' long x 14' wide by (3.5' shallow ends, 4.5' 1' into pool in middle, 4'9" at main drain) deep in-ground pool plaster surface. Hayward Super Pump C48L2N134B1 1 1/2 HP, Hayward Star Clear Plus Cartridge filter C1200. Jandy Caretaker 5-port. Tf-100 test kit
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Just so you are clear, the reason people are saying that the higher water level will not allow for good skimming is not due to a mysterious "pool rule". It's just that if the water level is such that it is higher than the top of the inlet inlet area of the skimmer mouth, then floating debris, leaves, pollen, etc. will not be physically able to float into the skimmer to be sucked into the suction pipe at the bottom of it.
    So pollen will accumulate on the surface and debris may have more time to become water logged and sink before being captured in the skimmer basket.
    It's nothing serious, more of a housekeeping item that you don't want to have on a routine basis. It makes it harder to keep the surface of the water clean. The water is still being filtered regardless, just not the surface of it.
    A little wordy but I was in an explanatory mood. If you already knew this just skip along!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
