Results 1 to 8 of 8
Thread: AQR-15 on a timer?
    May 2011
    Beaumont, TX
    5
    Question AQR-15 on a timer?
    I have a Hayward VS pump with a built-in timer. I'm installing an AQR-15 SWCG and the instructions say that it should only be on when the pump is running. Is it that important to run the AQR on a separate timer - coordinated with pump run times? Would it be asking for trouble, long-term, to hard wire it without a timer and let the flow switch control it? BTW, an automation panel is out of the question. Thanks!
    33' Sharkline Matrix, Hayward MaxFlo 2302VSP 1.5hp, FlowVis, Hayward S360t2 33" sand filter, dual main drains and three returns
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: AQR-15 on a timer?
    I would not recommend to hard wire it and have the flow switch control it.. Your just asking for trouble..
    an intermatic timer that could turn on and off the pump and SWG at differant times would probably work... I turn my SWG on 5 min after my pump and turn it off 5 minutes before the pump turns off.. you would need to find the correct one for your setup..
    you say automation is out but that may be the best option, I went with the Intermatic PE653RC Wireless Control System, at 375 it is more expensive but I really love it... it controls my pump, SWG, and my LED lights all with a wireless remote control that also showes outdoor and pool temps
    Intermatic PE653RC Wireless Control System for Variable Speed and Two-Speed Pumps - Sump Pump Accessories - Amazon.com
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    I also have a VS pump with its own built in timer. My SWG is wired to an old fashioned time clock so I can set the clock to turn the SWG on and off as needed. I run my pump a lot more than I run my SWG so I just make sure to have the SWG set to come on at times when I know the pump will be on.
    Getting the Hayward aquaplus or aqualogic with the cell would be better than getting an aquarite and a timer separately.
    Support the site
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    My SWG is also on a timer. The flow switch was designed as a secondary safety device and was not intended to be the primary control switching for the SWG.
    chiefwej
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Im with all the others, dont rely on the flow switch.
    I do exactly the same thing, for the same reasons pooldv does. The SWG on a timer is e.a.s.y. street.
    Quote Originally Posted by pooldv View Post
    Divin Dave,
    May 2011
    Beaumont, TX
    5
    That's a nice setup Casey! I appreciate the pics. Thank you to all. Timer it is!
    Jul 2013
    Waxahachie, Tx.
    448
    I have a hayward vs pump and swg. Everything is controlled with an intermatic timer
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
