Results 1 to 7 of 7
Thread: Dirty water pumped into pool after backwash
    Mar 2016
    Cape Town
    2
    After back washing my pool, dirty water is pumped back into my pool, regardless of the spider valve setting - rinse or filter. Literally dirty water flows the moment you start to rinse. No water bubbles out of the top of the spider selector. I replaced the sand in my filter this season. Not sure what could be causing this? Thanks
    Jun 2014
    15,198
    Re: Dirty water pumped into pool after backwash
    Hello and welcome to TFP! Are few things to consider:
    - Are you rinsing for a good 1-2 minutes?
    - When you replaced the sand, perhaps the laterals didn't get placed back correctly?
    - When you replaced the sand, did you first fill the filter housing with a good amount of water to prevent breaking a lateral from all the weight?
    - Perhaps your spider gasket is beginning to fail?
    - Lastly, new sand can at times require a more lengthy backwash; some people will backwash new sand a good 5 minutes or so, but after that it should be fine.
    Perhaps more ideas will come in as well.
    Also see: Pool School - Maintenance and Cleaning of Pool Filters and Deep Cleaning a Sand Filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    Most likely a bad spider gasket.
    Support the site
    30,427
    Water should not flow into your pool on the rinse setting......you have a bad spider gasket, almost surely
    Mar 2016
    Cape Town
    2
    Thanks guys, I opened my Spider gasket and found that the black rubber sealer between the different compartments (not O-ring) was perished badly. I have replaced that now but my pool is too dirty to see if the water was dirty after rinsing. I can tell you that no water was coming in while rinsing so I'm feeling hopeful.
    Jun 2014
    15,198
    That was probably it. Good luck and let us know if you have any more problems.
