Results 1 to 8 of 8
Thread: Possible Filtration problem
    Jul 2015
    Fairbanks, AK
    40
    I have a 35K play pool running SWG circupool. Filter is a triton sand filter with multiport valve. FAC 3.2 TAC 4.4 PH 7.5 ALK 115. Every now and then I will have a problem with what looks like to be foamy scum on the pool surface. It happens usually every other week and I think the filter sand is not the right type. I have attached a pic, not sure what the deal is.
    Commercial Pool Facility| Pool 35,000Gal, Pentair Inelliflo VS, Pentair Triton II 140, CircuPool SI 35 +| Indoor Spas 12,500Gal, Pentair Intelliflo VS, Pentair Triton II 100, Circupool Si 25+| Outdoor tub 10,000 Gal, Pentair Intelliflo VS, Pentair Triton II 100, Circupool Si 25+
    30,419
    Re: Possible Filtration problem
    If it hap[pens every other week, I would say a sand filter would eventually clean itself and it would stop or lessen.
    Are you putting algaecide in the pool?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    it looks like pollen to me? maybe wind change?? Try doing a deep clean on your sand filter..
    how long does it take to filter out?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Am I reading it corectly that there is 1.2 CC (4.4TC - 3.2FC).
    From your location and the reflection of the overhead lights I assume this is an indoor pool?
    Is there any CYA in the water?
    Support the site
    Jul 2015
    Fairbanks, AK
    40
    CYA 10, It is indoor pool
    May 2014
    Franklin, NC
    9,184
    With the high CC I'm going to guess you have a situation similar to a hot tub where waste products are not being oxidized and are causing the "scum". You may want to look into using an MPS shock.
    Support the site
    30,419
    Jul 2015
    Fairbanks, AK
    40
    I am not putting algaecide in the pool. I think it could be a lot of waste that is not oxidized. Thinking of maybe adding MPS shock after high use?
