Thread: Is this the boric acid I need?
    Brisbane , Australia
    54
    Hi
    I'm thinking of adding borates to my pool.
    Pool Calculator says I need 20 KG of boric acid to get to 50ppm. Is this type in the link all I need. So many different prices online.
    Boric Acid 25kg Bags Pickup Melbourne OR Ship Anywhere IN Australia From $40 | eBay
    Thanks.. brad
    19,000 gallons
    Zodiac Tri Series SWG
    Hayward S310T Sand Filter
    Poolrite SQI 600 pump.
    IG Concrete, quartzon surface
    Built 1997
    Donldson's Avatar
    NW Ohio
    2,916
    Re: Is this the boric acid I need?
    Yep, that should work.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    tnmasterplan's Avatar
    Apr 2014
    West Monroe, LA
    13
    Make sure you have Muratic Acid on hand - Borates will cause the PH to rise dramatically. My recommendation would be to add the borates in 1/3 doses with Muratic acid each time.
    Louisiana - 19,000 gal, Free form Gunite / Quartz Plaster, Flagstone Waterfall, Cartridge Filter, 1.5hp Hayward Pump, additional pump for waterfall. - Just purchased the Taylor K2006-C Test Kit based on feedback
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Quote Originally Posted by tnmasterplan View Post
    This is only required when adding borates such as 20 Team Mule Borax. When adding boric acid it is mostly PH neutral.
    Donldson's Avatar
    NW Ohio
    2,916
    Yeah, pH rise is when using borax or sodium tetraborate pentahydrate (ProTeam Supreme). Boric acid is slightly acidic
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Quote Originally Posted by pooldv View Post
    Quote Originally Posted by Donldson View Post
    This is exactly why I prefer to use boric acid instead of the other borate products. So much simpler not having to deal with acid additions.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
