Thread: Following pebble tek resurface turned on SWCG... now need balance the pool for salt
    Jul 2015
    Scottsdale, AZ
    24
    Hi all... I'm in the process of trying to get my pool balanced... Target is TFP standards for salt water pool. Current test results:
    • FC 6 ppm
    • PH 7.5 - goal 7.6
    • TA 100 - goal is 60-70; So I read in these pages that to lower TA bring down PH to 7.0-7.2, then aerate until PH is 7.6; repeat as necessary to reach TA goal. I'm guessing this is iterative... Any idea how many times this will be necessary?
    • CH 375
    • CYA 60 - working to get this up to70. Once the soc is empty will the reading stabilize or will it continue to rise?
    • Salt 3150 ppm - seems it was 3200 the other day, recommended is 3400. Added 80lbs yesterday... does the SWCG burn through the salt that fast?
    Any particular order I should approach this?
    I've been told having the CYA at these levels will cause the ORP reading on the intellichem to be off... I was thinking I might let the system settle, get the FC right, see where the ORP is and set that as the goal in the system... does that make sense?
    Finally, the acid injection system has kept the PH spot on. Make sense to add borates to further tighten the PH range? I imagine as we head into summer the pool will get into the high 80s and will be more of a challenge to keep in balance... Thanks for your thoughts!
    Owner in Phoenix 16.5'X37', 27,000 gal pool; rennovation summer/fall 2015 to remove in ground sytem, resurfaced w/pebble sheen cool blue and update all equipment: Pentair 011018 IntelliFlo VS pump; Pentair 160332 Clean & Clear Plus 520 sf cartridge filter; Pentair Auto Fill; Pentair Intellichem, Pentair EasyTouch automation (including SWCG); ThePoolCleaner (suction side).
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Following pebble tek resurface turned on SWCG... now need balance the pool for sa
    You are on the right track and doing great!
    Here is my fave page about saltwater,Pool School - Water Balance for SWGs
    I mostly only adjust salt when the SWG says to, if the SWG is happy and making chlorine then it's all good. The SWG does not "use up" salt, it is a continuous loop, salt to chlorine to salt, repeat ... Salt is only lost to overflow, draining and splash out.
    Don't know about your ORP.
    I am a fan of borates.
    You will get into cruise control mode over summer with tweaks to FC and PH and lots-o-swimming.
    Jul 2015
    Scottsdale, AZ
    24
    Thanks! Follow-up questions:
    • does the CYA reading stabilize or will it continue to rise once the soc is empty?
    • when driving TA down, any idea how many times one must lower PH then aerate... I'm sure it is pool size specific... rough idea?
    • Any particular order when balancing pool water (read borates last, salt first)
    • I've been told having the CYA at the TFP recommended levels will cause the ORP reading on the intellichem to be off... I was thinking I might let the system settle, get the FC right, see where the ORP is and set that as the goal in the system... does that make sense?
    DFW, TX
    24,485
    CYA reading will be stable in a week.
    Not sure on the TA repetitions, I just do it from time to time when adding acid, not repeatedly with a goal in mind.
    Order isn't that important except take your PH and TA in stages to make sure neither moves too much at once and get your TA down to 60 or 70 before adding borates
    here you go
    Salt
    FC
    PH
    CH
    TA
    Borates
    I am not familiar with Intellichem and ORP.
