Results 1 to 7 of 7
Thread: pressure gauge
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    pressure gauge
    This may just be the dumbest question of the day but......
    The pressure gauge that screws into my filter is broken.
    What exactly does it do? If everything is running fine and the water is clear and the Kreepy is working, does it really matter if it's working or not?
    NW Arkansas
    17,300 IG Gunite pool approx 16 yrs old (here when we bought the house in 2004)
    1.5 HP pump (rebuilt in '06)
    TA60 Tagelus Sand filter (sand replaced in '05)
    Re: pressure gauge
    There are no dumb questions. All of us had to learn how things worked at some point!
    You want the pressure gauge working so you can tell when the filter is dirty enough that it is time to backwash/clean it. As the filter gets dirtier, the filter pressure will go up. When the pressure rises by perhaps 6 PSI above the pressure reading when the filter is clean, it is time to clean the filter again.
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    Re: pressure gauge
    Thanks Jason,
    I'll get a new one
    NW Arkansas
    Apr 2009
    Virginia Beach
    4
    Re: pressure gauge
    I have the same problem, my pressure gauge is not doing anything, stuck at 60 whether the pump is on or off. Is it a special type of gauge or can I go to HD/Lowe's and just get any gauge. If I take it off water starts coming out, so I can't take it with me.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: pressure gauge
    Quote Originally Posted by mvtton
    Don't know if Lowe's or HD carry them. Most any farm store will have them for about $4 or you can get them at a pool store for $8-10 typically.
    Jun 2008
    North Carolina
    38
    Re: pressure gauge
    If you have a 2 speed pump, should you read the pressure gauge when running the pump on high or low? When mine is on low it reads 1 and on high it reads 10.
    Round 24' AGP
    13,500 gallons of cold water
    Sand filter
    BBB
    North Carolina
    Re: pressure gauge
    If you are trying to determine when to clean the filter, read the pressure gauge when the pump is on high.
